Panasonic sa-ht995 will not work ...... when turned on it says hello.......then f61 then turns off again how do i fix this problem?
  • 2 more comments
  • daryl121 Sep 13, 2008
    My panasonid sa-ht995 Home theatre system will not communicate with the se-fx61 wireless link for the two rear speakers. When swithed on the system tries to communicat (red light flashes and the wireless link Green light comes on for a few seconds and does not link. System is approx 2 months old and has never linked
  • deltaamir Dec 23, 2008
    panasonic sa-ht995 will not work have f61 error.
  • frosdee Jan 08, 2009
    same as f61 error
  • Anonymous Feb 22, 2009
    Turns on, flashes "hello", "reset", "F61" and then switches itself off.
  • 3 Answers
F61 in the user manual says , check your speaker connections if ok then see your dealer, the reason f61 comes up is a amplifier fault , most likely a blown audio amplifier ic is faulty, and needs replaceing by a compenent electronic technician.
Posted on Jun 24, 2009
Hi I have the same problem. It is the fan and i had to get a spare part via a authorised repairer and have it replaced. the cost was $233 including parts, labour and gst.
Posted on Mar 31, 2009
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HT740
Think I got it. Check your fan. Power it on and see if the fan spins for a few seconds and then stops. This is why mine kept giving me the F61 code and powering down. Remove the cover and use an air duster on the fan. This may not be enough so if you must, remove the fan (two screws + 2 clips) and pop it out of its housing. Dust the blades off and gently pull the fan away from its center as if you were trying to separate the two. There should be about a 2 or 3 mm gap there now. Dust that out and I even sprayed some lube (WD40) in for good measure. Put it all back together and make sure the fan spins and is quiet when you power up your system.
So far it's working for me. Good luck!
Feb 16, 2008 | Panasonic SC-HT995W System
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
1,582 people viewed this question
 Grubhead
Grubhead
