Question about Coleman Powermate 024 0179CT 2 In 1 Nailer/Stapler Kit
I have a powermate 024-0202 nailgun stpler and i am missing the lil black peice that goes on the tip of finishing gun it slides on so gtun doesnt make marks on trim? where can i get this piece?
MY NAILGUN QUIT FIRING NAILS. I LOADED UP TWICE AND USED NAILS BUT AFTER LOADING THE 3RD SET OF NAILS MY NAILGUN WON'T FIRE THEM INTO WOOD. WHAT I HEAR IS JUST A SMALL AMOUNT OF AIR FROM AROUND THE...
Sounds like you may have a nail jam. You didn't specify what type of nailer you have - most finish guns have a latch to open the nose & clear a jam - if it is a framer most of the time it requires a long punch and a hammer to push the driver back in past the jam to clear it.
Let me know if this does not fix your issue.
Nov 05, 2014 | Air Tools & Compressors
My senco sfn1 finish nail gun is leaking air
The SFN1 is a great nailgun, built for professionals, and is pretty much indestructible. It's air leak is most likely an O ring that is worn out. While it is theoretically possible to figure out which one it is, and replace it, the smart move is to have the gun rebuilt by an approved service tech. I usually pay about $60 to have my SFNs gone through. My oldest SFN1 is 18 years old, and it has only been rebuilt once.
Jan 25, 2014 | Senco Tools & Hardware - Others
Air is pouring out of the head of my NR83a Hitachi nailgun
It appears that there is a small o ring that has missed you attention in reassembly and has fallen out of the groove. re do the job paying to gaskets and o rings.
Mar 10, 2013 | Hitachi Nr83a- Strip Nailer-driver Blade...
How do i adjust the nail depth on my bostitch n80 sb
The part of the gun that touches the work surface and acts as the safety so the gun won't fire unless pressed down on something is two peices bolted together. If you losten the nuts the bottom part will slide up and down. If you make the tip longer, the nail will be left higher (proud) in the workpeice. If you make the tip shorter the nail will be set deeper (counter sunk) into the workpeice.
Aug 26, 2012 | Stanley Air Tools & Compressors
Nails fail to feed
Without knowing your model number here are some things to check, in order of difficulty:
1. First make sure you're using the proper nails for your gun. If your gun isn't specifically listed on the box of nails as compatable make sure they are seating in your gun properly. Some brands of angled nails are a couple degrees off from others and won't work in competetor's guns.
2. Check the entire feed path of the nails in the magazine all the way up to where the driver catches the next nail. Sometimes dirt builds up in the track or there could be a peice of nail stuck in there preventing the nails from getting under the driver. Also the spring on the feed shoe should have strong pressure on the shoe all the way up to the head and the shoe has to ride freely in the magazine.
3. If the gun is making holes in the wood the driver isn't broke but it must be straight and true and the tip square. If not it will miss or slip off the nail before driving it. The only way to check the driver is to remove the head on the gun and take the driver out. The piston & driver should travel from the top to the bottom of the cylinder without binding anywhere. Correct any problems you find or replace any damaged parts and your gun should work.
Feb 13, 2012 | Porter Cable 16 - Gauge Finish Brad Nailer...
My nail gun miss fires. seems there is not enough tension pushing the nails forward
Could be that the driver is not returning to top of the cylinder. Easy test, when the gun miss fires, remove air line, with thin metal, insert thru nose and push driver up. Retest gun. If driver was down a bit then nails will not feed. Remove head and check that driver oring is making good seal, lubed, and is not too tight or bent. Also check that lower bumper is not cracked or missing pieces. Replace parts as needed. If driver was all the way up, clean rails and pusher assembly with wd40 and follow with good cleaning with air. If pusher and rails working properly, must be problem with bad batch of nails, slightly thicker or wider head not allowing nail to easily slide. Open nose latch and check that nails slide thru easily.
May 10, 2011 | Porter Cable 16 - Gauge Finish Brad Nailer...
Why dose my Karcher K2.35 keep blowing the gun hose off?
There is a good chance you are missing the black plastic clip that holds the hose into the trigger gun. If you look at where the hose goes into the gun there should be a flat slot where a black plastic clip would slide in and keep the hose into the trigger gun.
Oct 24, 2010 | Karcher 2500 PSI Pressure Washer
My nailer was working fine when I finished work yesterday. This morning I went to us it and it won't fire. air comes out by the trigger. The tool is brand new. I have used it less then a week. Does the...
water in the gun........drain your compressor after every use to prevent condensation in the tank.....before every use of the gun put 2 drops of nailgun oil in the bottom of the handle of the gun where the air hose connects..that is very important ....oil should have been included with the gun when you bought it. check the case
Dec 23, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Nailgun does not work, air is
Check to see if a nail is jambed part way in the chamber outlet, make sure to take air hose off before checking. You also may want to add some air gun oil to the inlet if you havnt done it in a while
Oct 29, 2009 | Porter Cable FR350A Factory Reconditioned...
Installing nail brad in a non elecctric stanley nailgun
find the side of the stapler which says "load brad this side"
open the loader with the aforementioned side facing down
as you look down on the inside wall, there are grooves which the heads of the brads will rest on and will slide along.
close the chamber and you're ready to shoot.
Dec 22, 2008 | Electric Stanley Tre500 Staple Gun /...
Coleman Powermate 024 0179CT 2 In 1 Nailer/Stapler Kit Logo
292 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
