Question about GPS
Hi , i just purchased a blue ray dmp bd30. i wish to use it as to play cds. It is connected to my 2 channel amplifier from the audio outlets, it is connected through the HDMI connection to a Pioneer PDP-428XDA. is it possible to play cds with the plasma turned off? I have folowed the instructions which describes turning off power from the options menu, but the options menu doest display? Thanks , Martin
  • vantijn Jul 09, 2008
    Thanks , Martin
    The maanual discusseshow to use without the tv on, so there must be a sloution,
  • 4,472 Answers
So you are trying to play the audio from your cd's through the HDMI with the TV off? For that the TV has to be on. You should be able to hook up an alternate audio out from your blue ray player to your amp. This way you can listen to the audio with the TV off. So all you really need is one set of audio cables.
Hope that helps.
Thanks,
Lee
Posted on Jul 09, 2008
  • 1 more comment
  • Lee A.
    Lee A. Jul 09, 2008
    What is the model of your amplifier? I will need to know exactly what sources you have going to what. You have the blue ray player going to what? and what kind of cable are you using on the blue ray player? Is it going HDMI straight to the TV? If so you will have to use a different audio connection on the blue ray player to the amplifier. That is your best option.
    Let me know and enjoy.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 09, 2008
    What is the exact model of your "amplifier" also I need to know what inputs and outputs you are using on your tv, blue ray player, and "amplifier".
    Once I get all the information I know we can get it working.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 09, 2008
    Are you using HDMI from the blue ray to the TV and then to your amplifier?
    Thanks,
    Lee
  • 13,433 Answers
If the audio is going to the tv / speakers with hdmi, then no the screen has to be turned off.
Unless you setup a external sound system.
  • Ekse Jul 09, 2008
    Sorry, I mean the tv has to be turned on
  • Ekse Jul 09, 2008
    will need to get my hands on the manual, ones I find it il get back to you.
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Dmp bd30 will not play normal. It will only play regular DVDs.
Unfortunately the problem is in the laser pickup assembly, the Blu-Ray DVD requires a higher velocity and precision to play this type of disc and is the first to fail. The only solution is to replace the DVD Player rather than have it repaired, far cheaper in the long run.
Oct 10, 2011 | Panasonic DMP-BD30K Blu-Ray Player
BD30 makes a grinding sound when loading discs,
in most cases its a bad disc but if all disc are doing it then your glide tray needs to be re alined
Jul 04, 2010 | Panasonic DMP-BD30K Blu-Ray Player
For a blu-ray player model #DMP-BD30, how do we get updates
goto http://panasonic.jp/support/global/cs/bd/download/bd30/index.html
download this and put it on cd-r using a program like nero or whatever burning software your computer came with, then put the disc in the blu ray player, turn it off then back on and make sure it doesn't get interuppted
Sep 08, 2009 | Panasonic DMP-BD30K Blu-Ray Player
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Panasonic blu ray player ?
Jul 01, 2008 | Panasonic DMP-BD30K Blu-Ray Player
GPS Logo
37 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
