I've moved the computer & monitor to a new office & when all is connected up I get the message No Signal Input, check video cable, but all cables ie power & cable to computer are plugged in.
    Scholar:
  • 149 Answers
Make sure your monitor cable is screwed in on both ends. It is possible that your cable was damaged during moving, check for bent or missing pins on both ends of the plug.
Posted on Jan 02, 2011
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
Monitor stopped working - says No signal
Hi Paul,
This problem is often the result of a loose video cable connection on the computer or an incorrect video signal selection. Most monitors use a cable with "VGA" connector on the end that mates to the computer video port. Other modern computers make use of an HDMI (like the ones used to connect a TV to a BluRay Disk player) or DVI connector instead - either way if it is loose you will get the same "No Signal" message on screen. Make sure these connectors are making good contact with the port on the computer by seating them fully (or better yet - remove and reinsert). In the case of the VGA connector, most have two screws to hold them in the port - you should make sure both are threaded all the way in. You do not need to crank them down, finger-tight is more than enough.
Many newer - flat screen types in particular - do not have the video cable permanently attached. Instead, they use the same cord and connector arrangement found on the computer. It is possible that the connector has become loosened on the monitor end - especially if the monitor is moved / adjusted frequently. You should check the connections at the rear of the monitor just as you checked at the computer, too.
When satisfied that the connections at the computer and monitor are good, check the monitor again. If the message is still present, the monitor may be able to select between an analog input and a digital input via a menu item accessible from the monitor. Check your monitor manual for instructions to change inputs if unsure. If you are using the "standard VGA cable" (the one with the two screws) you should select the analog input. If you're using an HDMI cable, you should select the digital input. If you're using an DVI connector the input may be either analog or digital. When making a change, wait 5 to 10 seconds between toggling between the analog / digital selections to allow the monitor to sync the signal for proper display.
If you're still unable to display the desktop, it is possible that that someone has changed the BIOS options to select a different video card (if more than one is installed) or that the cable is defective.
I hope this helps and good luck!
Dec 17, 2012 | Computers & Internet
Dropped keyboard. Now display on monitor says 1. Analog input in power save mode - press any key or move mouse to turn on. I have done both, neither works. I have turned off system and I see it rebooting...
the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
Nov 10, 2017 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I have a synaps monitor model mt9bbk. The screan will go black and power led will flash.
Display Power management is being triggered because no input signal was detected. Verify that the video source is connected and on. (Computer, notebook, etc).
- Try another computer or laptop that you know is working properly.
- Do you see any change on the screen if the display cord is completely disconnected (often a "Test" or "Check Cable" message appears). - Inspect the signal cable from the monitor - worn? Any places where the cable was bent to an extremely small (acute) angle? (less than 75 degrees?) Try gently moving the cable around at either end and see if you get a partial signal on the screen (while connected to the computer). If you do, the signal cable is damaged, if possible replace it. try: www.monoprice.com
Apr 14, 2011 | Computers & Internet
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
Problem
hmm,
Exact message could Find a Closest solution.
anyways, what you might be getting is a message like,
No Input signal,Check Video Cable.
it means that the Connection from the Monitor to PC is Loose,
Connect them Secure and tight to FIx it.
Jul 16, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
NO SIGNAL INPUT - message
Hi Rick,
Most common cause of this error is when the video signal cables are knocked off rendering the connection from the monitor to the CPU loose. Turn off the PC and secure all connections. Have you had your computer moved or repaired where you need to remove connections? Some PCs have more than one video cards (video output) and you may have connected it in the wrong video port. You can isolate the problem further by connecting your CPU to a known working monitor (office, freind's, neighbor, 2nd home PC). The other way is to isolate the problem is to connect your problematic monitor to a known working PC and see if video will be displayed. If video is present, your CPU's video card has gone bad or the contacts are not seated properly in the slot. Best Regards
Mar 27, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
David Payne
David Payne
