Question about Dometic RM2652 Refrigerator
What is the difference between a RM2652 and a DM2652?
The first time I tuned on my DM2652 the auto light and check light came on and went off . Now no lights some on
check back see if plug has voltage or loose wire going in or bad fuse if all ok bad board
Jan 26, 2014 | Dometic RM2652 Refrigerator
Food freezes in DM2652 refrigerator
move temp sensor into coil unit if same then replace sensor
Sep 18, 2012 | Dometic RM2652 Refrigerator
How to replace 120v heating element on dm2652 dometic fridge
back access two black wires going to chimney and to board
Jul 17, 2012 | Dometic RM2652 Refrigerator
My dm2652 turns on but doesn't cool
Check the thermostat setting and check you have power from it to the heater if it is an absorption fridge or compressor if not.
Apr 21, 2012 | Dometic RM2652 Refrigerator
I have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Jun 06, 2010 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
1,030 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
