Got an Telefunken tape recorder typ 204 TS. It does not work- and when I look under the cover I find two broken thiny driving rubber strap . i guess one ( very thin) goes to the left tape weel and the oter goes under them in a way I haven´t been able to figure out. Where can I find new rubber straps- and who can tell me how to get them in place?
escapement
  • 2334 Answers
SOURCE: Emporio Armani AR0532 Sports Watch with rubber/plastic strap
Here is a link to Emporio Armani Watches (paste it into your browser):
store.emporioarmaniwatches.com
/products/H45820.jsp
- Cached
Click on your model, then click on Customer Care tab. Here you can send an email or even contact online or by phone and get your strap sorted.
Don't forget to rate, please.
Posted on Jan 05, 2009
stang68349
  • 7 Answers
SOURCE: I have a Emporio Armani
Depending on where you are located... Samuels Jewelers or Some Macey's (Lazurus's) carry Straps for higher end watches. If nothing else go to either Amazon.com or 111watches.com to order what you need there.
SOURCE: the record mode does not function on the right side.It does play on both sides!
Place the speed on X1 mode to make sure it is off the B mode and it should record.
Posted on Jan 09, 2009
SOURCE: new rubber strap required
Try
Oakley Customer Services
Oakley (UK) Ltd | Icon House | Icknield Way | Letchworth | Herts | SG6 1GD
01462 475400
infouk@oakley.com
Posted on Apr 01, 2009
Grubhead
  • 5487 Answers
SOURCE: Sony TC-530 hum in internal amplifier left channel.
Electrolytic capacitors are good at causing hum. You could try replacing some of them, they are not expensive. Otherwise you might have damaged the left channel amp semiconducter, whatever that might be.
Posted on Nov 27, 2009
Tape ejects and will not play
the tape player will first look to see that the tape threaded properly around the video and audio heads ... then it will check to make sure the tape take up reel starts to move before allowing it to continue .. if the take up reel doesn't move in a couple of seconds after insertion then the tape would spill out inside the machine and make a real mess ..in order to prevent that the machine ejects the tape.
take up reels often quit because the rubber wheels, belts or friction drive components have become hardened from age .. if the take up drive is not strong enough then it wont pull in the tape .. in order to prevent tape and machine damage the recorder ejects the tape .. that can also happen if the rubber parts have contamination or lubricant on the friction surfaces ... you can sometimes clean those wheels and parts using distilled water or special cleaning fluid .. dont use alcohol since that will remove elastomers in the rubber .. sometimes you can use a pencil eraser to clean up the friction surface by removing oxidized rubber... the proper fix is to replace the rubber take up reel drive parts if they are still available .. a rubber wheel liquid dressing is available that improves the surface for a while ..
the same problem happens in high humidity areas .. if the humidity is high enough then the tape tends to stick to the audio head and other guide parts .. if that happens then the take up reel will also stop moving .. warming or drying the tape and air (air conditioning or dehumidifier) can fix that but it takes a few hours ..
if a machine has not been run for a long time then sometimes just by cycling it many times trying fast forward and reverse can clean up the drive parts enough to get it working .. but do that on tape you can afford to lose .. be careful you dont end up with a lot of tape piled up inside the machine.
some late model high quality machines have a different drive mechanism that is more reliable .. sometimes you can find really nice machines at goodwill .. the better name brand ones may still have parts available .. the low cost units are considered disposable and are almost never worth the work that it takes to fix them unless you do it yourself .. the mechanism borders on genius but workmanship and mechanical cost cutting often resulted in machines that barely worked even when new ..
Mar 09, 2014 | Toshiba DVD/Video Cassette Recorder...
I turn the unit on I have power to the unit. I put a tape in to play and the tape does not play. nothing happens. the last time I used it was about one year ago.is there some kind of belt drive motor or...
The belt drive unit is only ran by a SMALL rubber band. It may be that the actual band is broken or the motor itself is shot. Unplug the stereo from the wall and remove the cover CAREFULLY, look in at the tape drive and check the "RUBBER BAND" first.
Mar 16, 2008 | Audio Players & Recorders
My microcassette tape recorder stopped working.
It is possible that the rubber drive belt has broken or the motor is bad. Turn the volume all the way down,hold the unit next to your ear and put it into a function. Listen for motor noise, a slight buzzing noise. If you hear that it is possible the the motor is good and the drive belt is broken.
Oct 29, 2012 | Audio Players & Recorders
IBM TS 3100 drive broken
how to repair Tape drive broken ts3100 ibm
Jul 04, 2012 | IBM System Storage TS3100 Tape Library...
I have a VCR Panasonic NV - FJ623 and when I insert a video cassette into it for playback or recording purposes,it always ejects the video cassette.Can you help, please?
I'ts likely that the record sensor that pushes on the tab on the tape is bent or broken. Making the VCR think you are trying to record on to a protected tape.
Oct 22, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Hi Got a guess watch with rubber strap which has broken any ideas
you will prob need the same strap as most are integral to watch if i remember Seiko make guess watches try there website first or try guess watches they will ask you for model and sometimes serial numbers and they will send it in the post to you or maybe ebay but you take a risk ..then pop round to your local repairer and ask them to fit it..
Mar 24, 2010 | Guess Watches
Rubber drive belts wanted for Aiwa AD-F810 cassette tape recorder
my aiwa brand cassete recorder model : TP-VS485 drive belt is broken, how replaced and where I can find spare parts
Nov 02, 2008 | Audio Players & Recorders
Brother EM430 white ribbon broken
do you see any impression of letters on the paper when you type? if you do the ribbon not lifting or not driving. If you do not see an impression the print hammer is not firing. try to lub it with wd40 or light Wait oil. some brother typ's have a rubber bumper under the print hammer that deteriorate & need to be replaced
Oct 24, 2008 | Brother EM-430 Typewriter
RCA CPR 250 camcorder not recording
I fixed it my self !
I guess I should start a website and charge $
Apr 09, 2008 | Video Cameras
SERIES LXI TV & vhS
I'm guessing the "black thing in side" is referring to the actual tape itself- ribbon like which can be spooled out of the tape case. If so, then your VCR may have a mechanical problem of some sort, which results in a "no tape transport" or "no tape takeup" problem. If the latter, the right reel (takeup reel) is not being driven. Older VCRs often used a small rubber rimmed drive mechanism to drive this reel. Newer VCRs (10 years old or less) pretty much use a gear drive. Something may be broken here, or perhaps the gear is stuck. This gear assembly has to swivel back and forth, from left for rewind, to right for takeup or fast-forward. Unfortunately, you can't see the gear once the tape is in the machine, at least not from the topside. Suggestion: Take the top cover of VCR off, look for this gear, and see if it swivels freely, look for broken gear teeth.
Apr 14, 2007 | Rio Go Video DDV9475 Dual Deck VCR
165 people viewed this question
 Grubhead
Grubhead
