Question about Sony Televison & Video
Sony,KDL-32L5000,LCD TV,REMOTE WON'T TURN IT ON/OFF
  • 613 Answers
Sometimes one button on your pad gets stuck. Sometimes we get liquids on the pad. I suggest taking out the battery(s) and using high grade alcohol (90%) and swabbing the pad real good and let dry or use hair dryer. Is this a factory remote?
Posted on Jan 02, 2011
3 Suggested Answers
  • 96 Answers
SOURCE: tv doesn't turn on ....i
Give these guys a shot, I have included a link to the part you need on ShopJimmy.com. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/sony-1-474-163-41-power-supply.htm
Posted on Sep 02, 2011
vinceisaac
  • 2432 Answers
SOURCE: I have a Sony Bravia LCD TV Model nubmer
hi good day if your sony bravia tv when you turn on is totally dead set or no stand by indicator the first thing you do is try not to use for an hour to discharge excessive voltage at power supply usually at primary capacitor also to reset the processor. now after an hour try to plug and turn on the unit observe if their is a changes like have an indicator. if still wont power on what you will need is to open the back cover use a philip screw driver to access the internal part. now by this time look for the power supply where the power cord connected since it was dead set check blown fuse first then look for any burnt parts also considered bulged capacitor which cause low voltage not to switch on processor replaced with same rating atleast 105c rating temperature. good luck hope it will help you thanks.
Posted on Jul 09, 2011
My Sony Bravia LCD TV will not turn on.
If no voltages,then replace all main capacitors,power ic and optoisolater ic,do not forget the rectifire diodes/bridge and the output diodes.
Nov 25, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Sony model kdl-32l5000 only works by unplugging and plugging back after about 5 minutes
power supply may need recap try with a hair dryer when tv in stanby to heat a bit without unplug it if after heat it will start?
Sep 14, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Sony bravia volume control not working with FIOS STB
found the problem after reading a post on this site. Last thing I used was DVD player so disconnected DVD Sony player, followed the factory reset instructions and now the volume works normally! It was the DVD player. Thank you so much for the info and lead. The problem is DVD not TV,
Jul 20, 2014
Apr 08, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Ir receiver not working
Fresh batteries in the remote control first and foremost. Also check the white buttons on top that the "tv" is selected. If it doesn't turn red, remote might be bad or need cleaning depending on age/condition. A little (very little) bit of grease or vaseline on the battery connectors is a good fix if they are corroded. be careful don't get that on your skin, use gloves.
Mar 24, 2013 | Sony Kdl-32l5000 32" Lcd Flat Screen Tv...
Code for Channel Master CM-7000 Digital TV converter box ? I need code number for Sony TV
If you do the setting up using device codes scan correctly (page 25 in the user guide ) it worked with my sony bravia KDL-32L5000.
Oct 26, 2010 | Channel Master (9537) Remote Control
KDL-32L5000 model cracked screen
Someone or something impacted the screen. There is absolutely no other way this could have happened. The cost of replacing the panel will far exceed the cost of a replacement TV.
Mar 13, 2010 | Sony Televison & Video
Televison & Video Logo
489 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
