Question about Kodak EasyShare M320 Digital Camera
When I turn on my camera it starts to turn on, the lens comes out and the screen says Kodak Easy Share System, then it just turns back off.
Make sure it is charged. And try it again while it's plugged in.
Posted on Jan 02, 2011
Kodak camera easy share LS443 the lense mechanism is jammed.screen at the back of camera states Camera error E45
Try gently tapping the back of the camera with the pal of your hand while you turn camera on.
Jul 29, 2008 | Kodak Cameras
Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Mar 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
When battery is put in red led in front turns on but lens will not extend or turn on it is an kodak easy share c763
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Aug 24, 2009 | Kodak EasyShare C763 Digital Camera
Camera wont Turn On
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EASYSHARE M763 Digital Camera
My Kodak easy share M1063 digital camera wont stay on
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
My kodak easy share M1063 turns on then shuts right off how do i
I had the same exact problem. When the camera turns on and then lens extends, hold the lens out while the camera shuts off. Then sort of move it around a bit. I did this and when I turned it on, it was fixed. I guess something was jammed in the lens.
Jun 24, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens won't go back in
some times if the batteries get wet it will short the system and it won't turn back on... if you dropped it something may have shifted inside blocking the messaging systems inside the camera. i would take it to a local camera shop.
Jul 08, 2008 | Kodak EasyShare C663 Digital Camera
Camera will not turn on...
Does it do this when hooked up to the charger? It might be the battery.
Jun 20, 2008 | Kodak EasyShare V603 Digital Camera
Cannot Start Up
Go to Kodak Technical Support- There may be an issue here that they will deal with free of charge.
Jul 07, 2007 | Kodak EasyShare V603 Digital Camera
Kodak EasyShare M320 Digital Camera Logo
283 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
