Toshiba Satellite A25-S207 Notebook Logo
Anonymous Posted on Jan 02, 2011
Toshiba Satellite A25-S2792 w/ XP & P4 has greenpower chord is lit and yellow battery light is flashing when power chord is plugged in. After I press the power button, the power chord light changes to yellow, begins flashing and the battery light goes out. Removing the battery gives the same results. Pressing and holding power button down for 20 seconds w/ battery out yields same result as well. Suggestions?
Anonymous
Level 2:
New Friend:
  • Expert 97 Answers
  • Posted on Jan 02, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
97
Questions
0
Helped
16077
Points
311
It sounds like you have a motherboard issue. Bring it to your local computer repair shop for analysis.
How do I bypass power-on password for Toshiba Satellite A25-S2792 Laptop
Hi Paul,
Which password do you mean? Some laptops might have a BIOS password which is asked for before the O/S loads up. Or do you mean a password within the O/S itself? (In which case what O/S do you use? Windows? Linux?)
2helpful
How do I bypass system password on Toshiba Satellite A25-S2792 Laptop?
If you want to reset the windows password, you can use some third-party software. I recommend Windows Password Buster. This software can help you create a password reset disk. And with the password reset disk you can easily reset the password.
Toshiba a25-s2792 No sound in windows 7
Yes,....good Ol' Windows updates. Known to knock a system partially out of commission.
Windows has lost the address to the Audio drivers. The reason it states Audio is working properly, is because Windows is full of it.
The Toshiba Satellite A25 series of Notebook PC's, did not come with Windows 7. It came with Windows XP. You, or someone else installed Windows 7.
The updates knocked the audio driver address file to the curb.
All you have to do, is install the Win7 installation disk again, and perform a Repair.
(Non-Destructive Installation)
OR, use the Restoration Disk, (Backup disk)
Toshiba eSupport does not provide audio drivers for Win Vista, or Win 7, for this model. Only Win XP,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=665687&rpn=PSA20U&modelFilter=A25-S2792&selCategory=2756709&selFamily=1073768663
Regards,
joecoolvette
{Do I think going to Device Manager, and rolling back the audio driver, or upgrading it, will help? NO }
VGA OF MY TOSHIBA SATELLITE A25-S2792
You can download any/allthe Windows XP or Vista device drivers for your model laptop from the ToshibaWEB site from their download page. Make sure you enter the model of your laptopso you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Dvd movies play stop play.when dvd rom catches up after a stop movie resume play. toshiba laptop a25-s2792
Better you can download GOM player from internet.
download and use the same.
If you found its helpfull, vote for me .....!!!!
Why does my a25 s2792 satellite shut off randomly whether plugged into the power supply or running on battery?
It may be a virus, or a driver issue. you will have to check through the error logs and see if there is anything that is showing up there to fix, Thouroughly check for Viruses, ensure all latest Service Packs are installed, and all the drivers are the latest especially the Video driver. See if there is any one program you are using when this happens, You could also try disabling one by one your programs that activate at start up. use start>>run>> msconfig, and go to startup tab, disable one by one, and reboot, keep going untill you have used them and tested all, also check the services too..
How to reset admin password.
Try remembering it ......
keep on trying the pass with caps and no caps log
keep wrighting it ....every time you type
Satellite a25-S2792 toshiba laptop soundmax integrated digital audio driver
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=665687&rpn=PSA20U&modelFilter=A25-S2792&selCategory=3&selFamily=1073768663&selModel=665687|PSA20U#
Toshiba A25-S207
That flashing light indicates that the laptop is not getting power, check and test your power cord. That light should be light solid when plugged in. good Luck
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
