Tomtom One XL GPS Receiver
Problem for Tomtom One XL GPS Receiver
No GPS Signal in TomTom One XL all of a sudden
By cpatax on Jul 09, 2008
Clarification Request
Posted by Mikey666 on Nov 11, 2008
I bought a TOMTOM XL at the weekend and never tried satnav. 1st time I hooked it to USB I just got flashing red cross. No operation at all. Scary. Resolved by removing everything from its storage and starting again. Scary. Today QuickGPSfix rendered its GPS useless so brought me to this site.
This device is going back to the shop. Needs to be reliable. It'll end up in a car crash. Who made this? Europeans?
Same Problem
May 05, 2009
-   I also have experienced the same thing.
What we discovered accidentally to fix it is to hold down the power button (I can't even tell you how long - maybe as long as a few minutes.) Eventually it seems to reset itself and the signal comes back. But I can't seem to figure out what the cause is in the first place, nor how to get it to reset every time. Grrrr!
-   Guest
Jan 22, 2009
-   One XL lost GPS Signal and USA MAP!-   Guest
Nov 28, 2008
-   tomtom was working and then poof ! NO VALID GPS SIGNAL and it has been one day...
My next trick: POOF and TOMTOM is being returned...may or may not choose another product...
-   Guest
Nov 22, 2008
-   this is a killer,i hate it-   Guest
Nov 17, 2008
-   no gps signal in tomtom XL-   Guest
Best Solution
posted on Sep 13, 2008
Helpful)
Guest
Rank: Apprentice  GPS  Expert
Rating: 0%, 0 votes
Same Problem with my "one" Tried all suggestions, firmware updates, etc. My unit is out of warranty and TomTom doesn't service out of warranty units. They give you $50 off a replacement unit, BIG DEAL.
DON"T buy TomTom, get a Gamin. Better service, warranty, reliability.
Solution #2
posted on Aug 05, 2008
Helpful)
asprot7643
Rank: Apprentice
Rating: 89%, 8 votes
the website says that you have to upload TomTom HOME from thir site and update your GPS signal once a week for optimum signal because the satellites move... the only problem is TomTom HOME seems to be more than a pain to load
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Aug 25, 2008
Helpful)
donner451
Rank: Apprentice
Rating: 88%, 29 votes
I suddenly lost the GPS signal today and could not get it back. All I got was the "No valid GPS signal". My solution was to tap on the GPS satellite bars when in the route map. this brought up the "Status summary page of the TOMTOM.
I then again tapped the satellite bar which brought up the "GPS Status" page. I then tapped the bar labeled "configure".
The radio button next to the option titled "Minutes (dm.m') was selected. I then moved the selection to "Degrees (d.d) and it started working.
I had just downloaded the GPS fix 5 days ago so it is not like this suddenly caused it to stop working.
This may not work for everyone but this is what it took to get mine working.
Cheers
Was this helpful?
Yes
No
19 people thought this was helpful
Solution #4
posted on Sep 08, 2008
Helpful)
MissLC
Rank: Apprentice
Rating: 86%, 5 votes
After working perfectly well last night, first thing this morning right when I needed my Tom Tom "NO VALID GPS SIGNAL."  Despite driving into another county with the help of the old fashioned road map - still no luck, still no valid signal.
This evening I have uploaded all the new updates that appeared in Tom Tom Home, and now i have nearly full signal again.  This worked for mine.  Hope it helps! x
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Jan 09, 2010
Very Helpful)
jvtexas
Rank: Apprentice
Rating: 100%, 3 votes
Holding power button for about 15-20 seconds seemed to reset the unit. GPS is back now.
Was this helpful?
Yes
No
Solution #6
posted on Aug 20, 2009
Very Helpful)
effervescent
Rank: Apprentice
Rating: 100%, 1 votes
I downloaded all the most recent updates, including the map correction option, then went outside and fiddled about with the configuration of the GPS status. It seems to work best on Degrees (d.d).
Was this helpful?
Yes
No
Solution #7
posted on Dec 30, 2008
Very Helpful)
krayzenvy
Rank: Apprentice
Rating: 100%, 6 votes
I have had my GPS (TomTOM One) on Waiting for Signal for 2 weeks now and I finally fixed it.
My symptomtoms (word play) were no signal at open areas, when connected to Tom Tom Home it showed exactly where I was and worked through the PC but when disconnected back to the same thing.
I called Tom Tom CS and nothing, FLash did nothing, factory defaults nothing, and updating did nothing.
What I did:
I charged the unit completely.
I took a paperclip and while off pressed on the reset button at the bottom by SD slot. I held it there for 30 mississippi's.
I did not turn it on after letting go.
I went outside to my car (parked on roof of parking lot) turned it on and set it on my dash vertically.
I left and came back in 1 hour and wallaaaaa. It is working perfectly!
Let me know if this fixes it.
xgranados@entouch.net
Was this helpful?
Yes
No
Solution #8
posted on Nov 23, 2008
Very Helpful)
raja_m
Rank: Apprentice
I had the same problem; after reading this solutions, I have installed all the updates using tom tom one home but it doesn't work, then I have connected my tom tom one with my lap and tried to access thru my lap using map correction option, then it starts working. I hope this will help you all.
Was this helpful?
Yes
No
Solution #9
posted on Nov 17, 2008
Somewhat Helpful)
oudsm
Rank: Apprentice
Rating: 75%, 5 votes
no GPS signal in tomtom one XL
Was this helpful?
Yes
No
Solution #10
posted on Nov 26, 2009
Not Rated)
hosso
Rank: Apprentice
Rating: 0%, 0 votes
i have had my tom tom one for about 3years with no problems but recently it has lost its gps signal.i have updated it on tom tom website but nothing still happens,can anyone help please
Was this helpful?
Yes
No
Solution #11
posted on Jul 31, 2009
Not Rated)
forhever
Rank: Apprentice
Rating: 0%, 0 votes
This happened when I came back from Brazil...i think when you get an an area where the tomtom has to search for new satellite coordinates or loses the signal for a certain period it has difficulty finding again, so:
Go in to tom tom menu and rerset tom tom to factory setting (in the menu/change preferences/reset to factory settings)
Once you do that it will prompt you that you will lose all your saved favorites and itineraries ( i went ahead and said ok, if not you can write you addresses down before doing this)
Finally after you complete the process of resetting your tomtom probably still won't have a GPS signal. So in the menu/change preference/GPS status you will see a configure option
Select this option and ensure that the radio button is set to degrees and select done
leave tom tom on and allow 5-10 min for it to relocate the signal.
If that doesn't work, hope you bought a warranty :)
Was this helpful?
Yes
No
Solution #12
posted on May 15, 2009
Not Rated)
oldreliable6
Rank: Apprentice
Rating: 0%, 0 votes
having charging problem. sometime tom tom will come on by itself. scary. any suggestions
Was this helpful?
Yes
No
Solution #13
posted on May 07, 2009
Not Rated)
pjs01
Rank: Apprentice
Rating: 0%, 0 votes
Had a GPS signal/no satellites problem on my TomTom One XL, unable to get a signal for three days and really not impressed. TomTom was up-to-date with firmware etc and TomTom help is next to useless so I tried re-setting the unit, changing the satellites, chucking the unit across me cab, shouting at it and nothing! And then just for fun, I placed the unit on it's side on my windscreen and guess what? I now have a complete signal again and TomTom is working fine. I am not an engineer or anything, just a simple HGV driver but now I'm thinking I should be working for TomTom! Give it a try and if it works for you... GREAT!
Hope this helps!
Regards, Pete
Was this helpful?
Yes
No
Solution #14
posted on Apr 08, 2009
Not Rated)
heidelburgh
Rank: Apprentice
Rating: 0%, 0 votes
My Tom Tom XL also lost its GPS signal after 2 months of reliable use.... 2 days later, still no signal... so I tasked my hubby to return it which took a number of days (by which point the battery had died) I asked him to charge it enroute to the retailers to prove upon arrival that it wasnt working and voila! It was working again?! Maybe the flat battery did a reset? But its working fine again now.....bizarre...cant say I have complete confidence!
Was this helpful?
Yes
No
Popular Solutions for Tomtom One XL GPS Receiver
Questions and Unsolved Problems for Tomtom One XL GPS Receiver
Do you recommend Tomtom One XL GPS Receiver?
Answer
Answer
how do i change the home address in my tomtom xl
Answer
I have recently bought the XL 325, when i put in my address to where i am going the the time when i... (More)
Answer
tot tom turned off now wont turn on even thro its charging
15 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Oct 01, 2008
Fresh out of the box. Installed latest software and nothing...
Comment by inkaholic33, posted on Sep 19, 2008
same as above.. updated new version. gets not signal.. even after going back to old version the signal is gone
Comment by Guest, posted on Sep 01, 2008
Mine did the same thing last night. Turned it on, and it looked like it was trying to update or load files, then no GPS signal. I suspect a bad update from Tom Tom.
Comment by suzicc, posted on Aug 18, 2008
My tomtom one xl-s has been working just fine. While I was on a road trip this weekend, it suddenly could not find a gps signal. I have tried resetting it and powering it on and off but no luck. It still will not find a gps signal. What do I do now????
Comment by swm33m, posted on Aug 10, 2008
Well i have a tom tom and i think it is a piece of junk i wish i would have bought a GARMIN like i was supposed to do !!
Comment by worldchoice8, posted on Aug 10, 2008
Tom tom is not receiving any signals when turned on.
Comment by andy611, posted on Aug 02, 2008
Exactly the same issue. All working fine then switch it on again and no GPS signal.
Tried updating, reset. Turn off, turn on......Nothing.
Comment by shrubs, posted on Aug 01, 2008
Brought It last Week and was working dine.. now it can't find the GPS Signal.. what is going on?
Comment by Guest, posted on Jul 21, 2008
Driving through West London just stopped receiving signal. Went through the reset with Tomtom technical help but with no luck - have had to send it off for repair - luckily still under guarantee. Purchased from Currys last August (2007)
Comment by samantharosa, posted on Jul 21, 2008
My tomtom XL suddenly can't find a valid GPS signal for the past week.
Describe your GPS Devices problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top GPS Device Experts
Top GPS Device Repairmen
(408) 298-8188
Auto Nav 2000 Plus, Inc can repair most portable...
Auto Nav 2000 Plus  IS YOUR ONE Stop GPS Store
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
