Question about Pix FUJIFILM Fine S1500fd Digital Camera
Fuji finepix displays zoom error - Pix FUJIFILM Fine S1500fd Digital Camera
  • 4 more comments
  • Anonymous Dec 03, 2008
    When i turn on the camera, it display Zoom Error.
  • Anonymous Jan 02, 2009
    my lens will not open and the screen says zoom error.
  • Anonymous Feb 20, 2009
    ERROR DE ZOOM COMO LO SOLUCIONO....
  • Anonymous Mar 21, 2009
    my room mate dropped it last night and now the lens wont retract or zoom.. and i get the zook error now..
    anyway to fix this?
  • bklk Apr 23, 2009
    Zoom error on my FinePix S700
  • Anonymous Apr 27, 2009
    I have the sames proble with my photo camera finepix a800
    Problem Solver:
  • 11 Answers
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
Posted on May 31, 2009
SOURCE: Zoom error
hi i had the same problem with mine,i took the case apart but could see nothing untoward,reassembled it and just out of frustration i turned camera on if you listen carefully you will hear a whirring sound as soon as it starts turn camera off do this repatidly a few times but do not let the motor finish its cycle,hey presto no more fault. i can only assume that the motor sticks and by turning on and off really quickly frees it up...
Posted on Jan 07, 2008
SOURCE: Fuji FinePix S7000 Digital... Problem: Zoom Error
Fuji FinePix S7000 Didital Problem:Zoom Error
Posted on Oct 11, 2008
  • 11967 Answers
SOURCE: Zoom Error with Fuij FinePix - looking for "telephone trick"
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 28, 2009
  • 11967 Answers
SOURCE: I have a Fuji Finepix Z70 zoom error
Posted on May 07, 2010
  • 11967 Answers
SOURCE: Fuji j38 zoom error
Posted on Jul 23, 2010
Fuji Zoom Error Message
Here is someone selling the full service repair manual for the a500 for 5$. I coultn't find it anywhere online for donwload but I will keep looking...
Dec 19, 2007 | Fuji FinePix A500 Digital Camera
Fix zoom error
The lens probably has some dirt or pocket fuzz caught in it. Try spraying around it with a can of compressed air when it is extended. Also spray the lens.
Oct 05, 2017 | Fuji FinePix S2000hd Digital Camera
Display shows "Zoom Error".
In this link can find details about everything you can try to fix it without sending it to a repair shop: Fixing-lens-error-on-digital-camera
Hope helps (remember to rate and comment this answer).
Mar 31, 2011 | Fuji FinePix S304 Digital Camera
Zoom error
Some time later it suddenly worked again.
Jan 04, 2009 | Fuji FinePix F30 Digital Camera
Fuji FinePix A345 Lens cover does not open and Zoom error displayed on LCD
Lens cover does not open and Zoom error displayed on LCD.
Aug 25, 2008 | Cameras
Fuji FinePix S700 Problem
Try to put it on super macro and see if this will reset the zoom function.
Also try to switch between the settings that allow the digital zoom, as compaired to those settings that only allow optical zoom.
If these do not work, you may have a lens that has been dropped, or is stuck, and may need to be serviced. I have the S700, and have never seen this error before> good luck.
Jun 12, 2008 | Fuji FinePix S700 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
The manual describes all warnings the camera displays. Check the manual or go here for the manual online in pdf format.
http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf
Dec 13, 2007 | Fuji FinePix S7000 Digital Camera
Pix FUJIFILM Fine S1500fd Digital Camera Logo
321 people viewed this question
Top Pix Cameras Experts
Andrew Taylor
Andrew Taylor
Jay Plesset
Are you a Pix Camera Expert? Answer questions, earn points and help others
