Question about Whirlpool Washing Machines
I need to refit the rubber door seal i managed to take it off but not sure how to fit the retaining metal band
  • Steve Barrington
    Steve Barrington Jan 02, 2011
    What is the model number?
    Genius:
  • Whirlpool Master
  • 1,467 Answers
Its quite simple if you removed same....Assuming you have refitted the door boot seal the inner ring is normally fed on then tightened up with a securing screw some rings are a spring which needs to be stretched on to the seal, a good video is available at utube .com FIT DOOR BOOT SEAL
Posted on Jan 02, 2011
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
How do I remove and refit the door seal? I'm managed to remove the clip at the front but something I cannot see is attaching the rubber seal at the back.
There is another retaining band , clip, or spring holding the seal to the front of the drum, you need to remove this to remove the sea,double the seal back inside the drum to expose the retainer.
Aug 20, 2010 | Zanussi F1045W Front Load Washer
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Oct 05, 2009 | Hotpoint WMA31 Front Load Washer
Kenmore elite washer metal band on gray seal
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
GE Front Loader rubber boot completely out of shape
You can replace the rubber door seal yourself if you are logically minded and are handy with tools. Isolate the washer from the mains supply. Remove the top fixing screws at the back of the washer. Slide the top of the washer to the rear of the washer and remove. Now you will be able to see the outer drum and the securing band to the drum. This needs loosening and moving clear of the outer drum so you can disconnect the seal from the drum. When you open the door, you will find see that the door seal connects to the washer outer body. You should see a holding catch probably made of plastic. This has to be removed and take care not to break anything. When re fitting the seal,you will find on the front inner edge a small hole, this must be in the 6 o'clock position. Working from the door access, feed the new seal on the outer drum and secure it with the retaining band that you removed earlier, at this stage do not fully tighten as you may need to readjust the seal later on. Now working at the door, feed on the door seal and position the small hole at 6 o'clock. If you find that the seal is twisting, then you will have to readjust the the seal on the inner outer drum. When everything is lined up, tighten the inner securing band then the outer retaining band by the door. Recheck that the small hole on the door inner lip is at 6 o'clock and both the door an outer drum securing bands are tight. This done, check for leaks by part filling the washer and then putting the washer on an emptying cycle. If all is well, then isolate the power to the washer and refit the the top of the washer and secure with the screws you removed earlier. On no account put your hands or tools inside the washer when it is on and connected to the power supply.
I have not yet replaced a door seal on your model of washer, but I have done quite a few and the process is the same. I hope you can follow these instructions and if you come across a snag, think about it and i am sure you will find the solution. You can always get to me at FixYa.
Oct 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Replacing a rubber door seal on washer machine
1. Remove door (2 screws).
2. remove top (2 screws at back, sharp slap to front to dislodge).
3. Remove 2 screws holding powder dispenser to inlet valve.
4. Remove 2 screws at front corners securing fascia.
5. Remove fascia and powder dispenser as a unit - note plastic locating pegs on underside and plastic clips locating bottom onto front panel. Take care not to drop one of the rubber seals from valve/powder dispenser joint. Do not disconnect the wiring, just lay the complete assembly on top of the machine.
6. At some point, you will need to release the retaining wire securing the seal to the front panel. This is a thin spring loaded wire. Look after it, you will need it again.
7. Remove two screws at front securing front panel.
8. Remove kick panel - this allows access to two more screws securing bottom of front panel - take these out as well.
9. unclip the wire connector to the door switch.
The front panel may now be lifted from its plastic retainers.
10. The second wire clip can now be removed. The clever clip will need to be released to allow refitting.
11. Thoroughly clean and disinfect the seating for the new seal - you don't want the same gunk growing into the new one straight away.
12. On the drum, you will notice a protruding moulding at about 5 o'clock. There is a matching flange on the seal to help you locate it accurately - start here and fit the seal.
13. Fit the wire retainer - you will need a good pair of long-nose pliers to retension the wire.
14. Reassemble the machine in the reverse order - take care not to mix up the screws! remember to fit the seal to the front panel before refitting the door. Do not release the spring from the wire, carefully stretch it into place.
Aug 27, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Whirlpool Duet
hiya
firstly you will need to unplug the machine, then remove the lid, open the door and remove the metal retaining band from around the lip of the door seal (may need a small flat screwdriver to lift it up).
once the retainer is off the door seal should pull away from the front lip, this can then be folded inside the machine and out of the way for the next bit.
next you will need to locate the doorseal retainer on the inside of the machine may need a 7mm socket and small ratchet or a small philips screwdriver for this one, this one only needs to be loosened enough so that the doorseal will pull away from the drum.
refitting is pretty much the reverse of removal.
you MUST make sure the seal is on the drum lip corrrectly before refitting the retaining band or it will leak.
you MUST also make sure the drain holes are lined up with the ones on the drum.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The top of the rubber door seal has come away from the wire that holds it in how can I put it back
first remove the wire retainer (usually has a spring attached) then fold the rubber lip of the door seal back over the metal lip on the front of the machine when correclly positioned refit the retainer by starting at the recess where the spring sits and stetching it all around the seal making sure that it is sat in the groove where it fits, it is fairly easy to replacestarting from the spring and following around clockwise making sure that it is seated right as you reach the other end of the spring the spring will stretch allowing you to finish tucking the wire in and the spring should then tuck in to the recessed part of the seal
Jul 19, 2008 | Bosch Washing Machines
Replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Sep 28, 2007 | Washing Machines
Washing Machines Logo
183 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
