Question about Cambridge Audio Azur 640P Amplifier
The best connection from my 640p to my 840A v2 amp
  • Anonymous Mar 15, 2014
    Hi! I have just had my Azur 840A amp back from the repair shop to replace the standby PSU which was damaged in transit. Now, when I turn the amp on, the LED readout says SPEAKER CHECK. Then SPEAKER ON for a split second. Then CLIPPING. This is without any music actually playing. If I disable clipping then the amp is only working through the left speaker out. Any ideas? All best wishes, Nic
  • 682 Answers
Best connection from pre-out to aux in.
Posted on Jul 15, 2008
Azur 840A Clipping
CLIPPING occurs when the level of sound is way too high.
Try changing the speaker-wires -- you may have a short-circuit someplace in the wires that is causing "feedback".
Mar 15, 2014 | Cambridge Audio Audio Players & Recorders
Cambridge audio azur 840a volume control problems
The volume control is a resistor ladder controlled by software. If powering off the unit for an hour doesn't fix it, I would imagine that one of the "steps" has a problem. Contact your dealer or visit
May 02, 2012 | Cambridge Audio Azur 840A Amplifier
Just set up my brand new cambridge audio azur 650a amplifier. It keeps cutting out with the protection light blinking three times indicating "overvoltage" according to the manual. I'm using it at...
Just make certain that the connections are all good with no wires touching. If it still doesn't perform after that return it to where you bought it and get a new replacement or your money back.
Feb 16, 2011 | Cambridge Audio Azur 650a 2Channel...
Since gales last week and flickering house lights for over 24 hours my cambridge audio a740 won't switch on. Any connection? Not the plug fuse. Help.
Just take the top off! As long as it's unpluged from the mains you wont hurt yourself.
This is perhaps what you are looking for:
Apr 04, 2010 | Cambridge Audio Azur 640P Amplifier
I use an azur intregrated amp 540A and a Azur Pre amp 640P. When first power up, The amp makes a popping sound and the volume turns down. Some times it can pop 2 or 3 times within a few minutes. Then it...
I've never repaired one of these but I have an amp at home that makes a intermittent static "popping" noise that i'm going to put down to a dirty volume pot (control) that needs cleaning. I will also have to change some of the electro capacitors that have dried up inside which cause "shot noise". With the right lubricant (electrical contact cleaner, nothing else) you could take to lid off and spray a small 1 second blast into the hole of the pot and any other balance or tone control yourself but I would take it to the electronics repairer to get the capacitors checked over.
My theory only
Good Luck!
Jan 17, 2010 | Cambridge Audio Azur 540A Amplifier
Display fading on AZUR 840A
Did you take the time to fill out the Warrenty Card? It's VERY important that you do when you buy ANYTHING, especially electronics. Call the store where you bought it. Ask them if they can track it (the sale) If it can be fixed under warranty, be prepared to have to ship it back to the manufacturer.
Dec 28, 2009 | Cambridge Audio Azur 840A Amplifier
Cambridge Audio A5 AMP - Unit will not turn on.
i had the same problem with a tv a while back , the tech told me it was a dry and brittle circuit board they are ok until you move them and then they can sometimes crack a circuit , so my advice is get it fixed and then dont move it if you can help it
May 17, 2009 | Cambridge Audio Azur 640P Amplifier
My Cambridge azur 540C compact disc player won't read CDs.
After about 100 CD-DVD units, I've found that most problems are from debris/film on the laser lens.
If taking the cover off the unit doesnt scare you, unplug it and blow out the CD assembly with a can of compressed CO2
and VERY lightly clean the laser lens with 91% or better alcohol on a cotton swab.
If that doesnt work , contact Cambridge Audio for a repair service.
Jan 02, 2009 | Cambridge Audio Azur 640P Amplifier
Connection of ipod touch with Cambridge Audio 840A
Get a 2.5 mm stereo cable to dual RCA ( phono plugs)
Radio shack or Walmart will have them.
Connect it to the aux or CD input in the rear of the amp.
Dec 29, 2008 | Cambridge Audio Azur 840A Amplifier
Sound Distortion
use sonic slide switch and make ground connection between your 640p and turntable.-check cables and test with another good cables.-shut down any light dimmer around you and test.
Jun 29, 2008 | Cambridge Audio Azur 640P Amplifier
Cambridge Audio Azur 640P Amplifier Logo
321 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
