Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Both ovens overheat regardless of temperature setting, e.g., I set a roast temp of 325 on the panel and placed two known-good oven thermometers in the oven. On multiple tests, both ovens indicated over 500 degrees on both themometers before I shut the ovens off. I don't know how high they might have gone if I hadn't shut them off.
  • Jenn-Air Master
  • 1,902 Answers
Hello & Welcome to FixYa
Overheating is caused due to open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jan 03, 2011
Testimonial: "Thank you very much for your help! "
I am cooking a roast beef dinner for Christmas I bought a 13lb chuck boneless and I need to know how long to cook in in a traditional oven.
5 After browning the roast at a 500°F temperature in the oven for 15 minutes, reduce the oven temperature to 325°F. To figure out the total cooking time, allow about 11-12 minutes per pound for rare and 13-15 minutes per pound for medium rare.
Really, you need a probe thermometer. Leave it to rest for 15 minutes after you take it out of the oven, loosely tented with foil. I am a chef!
how long to cook Google Search
Dec 24, 2016 | In Microwave Ovens
What temp and how long yo cook a 5 1/2 pound prime rib roast
Cook the roast for 15 minutes, then reduce the oven temperature to 325 degrees F. Continue to cook the roast until your meat thermometer reads 110 degrees F. Estimate about 15 minutes of cooking time per pound of prime rib.22 Dec 2014
The world's easiest prime rib roast: Master a holiday classic - Today.com
www.today.com/food/world-s-easiest-prime-rib-roast-master-holiday-classic-t77026 What temp and how long yo cook 5 1 2 pound prime rib roast Google Search
Nov 27, 2016 | Grilling
How long in the oven and what temp for medium rare what temp for the oven to be set at
A lot depends on the oven itself, whether it is fan forced, how well it holds heat etc.
Preheat to 240°C/475°F/ gas 9, place the meat in, and turn down to 200°C/400°F/gas 6. Cook it for about 1 hour, then take it out and place it covered on the serving dish for 15 min. before carving. This first go may need to have slightly modified times for the next roast you cook.
To get a perfect result you really need a meat thermometer
http://i.stack.imgur.com/blUvw.jpg
You don't need to put this in the oven with the meat, just insert the tip to the middle of the roast when it gets near time to see what is happening
Medium rare (? point) warm red center; firmer 55-60 °C Medium (demi-anglais) pink and firm 60-65 °C
Jan 07, 2016 | Omaha Steaks 2 1.5 lb. Tri-Tip Roast
Why hasn't the oven reached the set temp when the buzzer sounds indicating desired temp has been reached?
What are you using to measure the temperature of the oven? If you using a typical round oven thermometer, the reason is that your thermometer response is slow. It takes about 20 minutes for those thermometers to reach and display the actual temperature, and your oven is probably reaching it's set temperature in about 10 minutes. You really need an electronic thermometer or at least one of those liquid thermometers which you can sometimes find at Ace Hardware or True Value Hardware stores.
Apr 29, 2015 | Kenmore Kitchen Ranges
Whirlpool Accubake Wall oven, RBS305PD86 will not heat over 350
The first thing to ask yourself is "Is the thermostat accurate?"
Get an El-Cheap-O oven thermometer at the grocery store. Set your oven for any random temp, say 325. With the over thermometer HANGING FROM A RACK IN THE MIDDLE, wait until the oven light that tells you it is heating goes out, indicating that the oven is at 325. Open the door and QUICKLY read the thermometer you have hanging in there. IF the hanging thermometer and the temp displayed on the oven match within, say, 25 degrees then we have an issue. And, as you say that you have already replaced the temperature sensing element, that only leaves the control board or the upper and lower safety thermostats. Those are what we call "Snap Disc" thermostats. To see a typical snap disc thermostat, go to ApppliancePartsPros.Com or just BING (NEVER 'Google') Part Number: AP3055315. These theremostats may be opening prematurely, preventing the oven from reaching full temp. And once the oven cools, the snap disc will close again, allowing the unit to work. Kind Of. If it's not one of the safeties, the board is toast.
Nov 26, 2014 | Whirlpool Kitchen Ranges
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Lg lst5651sw problem
One burner is out either the top or bottom.
Nov 04, 2013 | Kitchen Ranges
The oven does not heat to the set temperature. It is usually much hotter
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Nov 15, 2010 | Amana RanARG7302 Gas Kitchen Range
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
395 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
