Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Panasonic PT-50DL54 50 in. Color spectrum off
I've have my Panasonic DLP TV for about three years now and just yesterday when I turned it on, I noticed that the color was way off, almost like all the red was gone (and I can't get the red back, no matter how much I adjust it, or reset the color). Normal skin tones are greenish, and even with adjustment are, at best, very yellow.
Does anyone know what I need to do to fix this problem? I had the lamp replaced a year ago (while still under waranty), but I'm no longer under waranty...and still would like it fixed. Any suggestions?
  • Dustin Claud May 11, 2010
    do you have a cable box or sattelite high def?
    Problem Solver:
  • 7 Answers
If it is hooked up with component cables, the red blue and green one could be loose or bad. ouble check that. also bypass the box completely and hook the cable straight into the tv and see what the picture looks like. If its good then something is either wrong with the component cables, cable box or TV itself. If you have multiple component inputs on the tv, try a different one and see if the problem still exists. it is possible that the board on the tv is shot as well. Call the cable company and have them take a closer look.
Posted on Jul 11, 2008
Yes, I have a cable box, and I do get high def channels.
Posted on Jul 09, 2008
Limited color on screen primarily blue, white and green. I use to be able to fix by giving the screen a gentle wiggle but color spectrum is gone.
Sounds like you have a bad joint on the tv circuit board somewhere.There is another thing it could be if you have a scart lead connected. Pull it out and check to make sure none of the pins are dissapearing inside the plug. Sometimes they slip inside. Check both ends of the lead.
Feb 16, 2012 | Panasonic TCP42C2 42 in TV
I HAVE A PT-50IN LCD14 THATS HAVE YELLOWS SPOTS COULD IT BE THE COLOR WHEEL
? DLP or PLASMA ;dlp have a color but not plasma/
in plasma its could be a floating ground or a bad capacitor
in the video board or filtering capacitor in pwr supply..
hope that give an idea about its problem..
regards Allan (asleletroniq1.
Oct 01, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Color on tv
If this happens to all the input sources, the main logic board is fired. If this happens to only one input source, only that input source circuit is fired.
It is costly to replace the main logic board. And then there are other components ready to die out soon.
Your set is at least 5 to 6 year old. Have you replace the lamp yet? It is rated for 10,000 hours. Yes, it will fail in about 10,000. Off brand replacement is cheaply made, can cost problem. (mine did). The nut holding the wire to the lamp was loose.
Time for a new TV. A new 46-47 inch LCD is less than a grand.
Apr 01, 2010 | Panasonic PT-50DL54 50" Rear Projection...
My panasonic dlp model pt43lc14 shows yellow picture
there are many mirrors, filters and lenses in the projection assembly, This happened to me too. I took the assembly apart and there was one of the filters that had gotten charred. I peeled off the plastic filter and cleaned the glass it was attached to then put the TV back together, now have a perfect picture again.
Dec 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
I might have issues with my color wheel, Im bnot recieving a picture with full color!
if tv is lcd it has three color filters which can be damaged by heat.If it is dlp then it has a colr wheel which spins.they are located in the light engine.alcd tv has 3 lcd panels a color filter(red green or blue)is mounted behind panel coloring light going through lcd.prisms combine pictures before going through lens. If color burns off of filter then color of picture is affected
Oct 19, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-52LCX16 DLP TV color problem
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Apr 26, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt 52lcx66 won't turn on
Sounds like the light engine. Is this a DLP or LCD rear projection? Did you see any patches of color any time before the problem with the really dark screen. Please rate my answer and let me know what other questions, Tech Malick
Jan 31, 2009 | Panasonic PT-52LCX66 Projection Television
Panasonic PT-52DL10 DLP TV
Color wheel bearing can make the noise you describe, and that will also cause color distortions.
Feb 15, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
Dec 02, 2006 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
195 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
