Question about American Standard One Handle Shower Only Faucet 2000.501.295
Water will not flow through on american standard with pressure balance. Some hot water came out with low pressure then stopped and now nothing will flow.
I just spent a week wrestling with a similar problem, and I'm posting in an attempt to save someone else an ulcer. Using a Colony single-handle valve, the temperature got so we couldn't control it. Either all hot or all cold. I called A.S. and they sent a new pressure balancing cartridge and new valve cartridge. Replaced both and then there was no water at all coming out of the shower head. Tried every possible combination of old and new parts, flushed pipes, etc. Finally took the shower head off and found it completely clogged with debris. It was a mix of sediment and the white grease that was in the new cartridges, which must have been displaced when I started messing with it. And it clogged it all at once (no flow problems before all of this). Works fine now!
Posted on Dec 25, 2012
5 Suggested Answers
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 171 Answers
SOURCE: kitchen faucet , reduced water flow / pressure
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
  • 11 Answers
SOURCE: Hot water tap - no pressure and splutters
Do you have your own hot water tank? or is there one serving many units? There is a 'dip tube' in hot water tanks, if it gets old it sometimes deteriorates and small parts of plastic get loose and will float around in the tank, if a piece finds it way up to the outlet then that might explain why you are getting the low water pressure. one wat to check is to twist off the aerotor on the end of your faucet, if there are any small pieces of white plastic then you will have to replace the dip tube and maybe even flush out the tank. it is also possible that a piece of plastic has traveled up the water line and it stuck in the faucet cartridge.
Posted on Feb 11, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
How do I get more water pressure from my american standard shower set
Hi Fran:
Most shower faucets now are equipped with flow restrictors. It is possible with some units to remove the flow restrictor plate from the shower nozzle. It has to be dis-assembled to do that.
Regarding the lack of hot water, that would usually be a different problem and will be related to the hot water source.
Hope this helps.
Dec 30, 2015 | American Standard Plumbing
No water flow from new american standard marquette showerhead
I think fitting of your shower is not proper. You have to fit it properly if you can or you can call a nearest Plumber to solve your problem.
Mar 13, 2014 | American Standard Home
My American Standard R120 shower valve has excellent pressure on the cold side, no pressure on the hot side.
Could be a chunk of scale in the valve. Need to turn off water supply and take valve apart. If nothing is found, turn water supply on to give line a 'quick' flush and turn back off. If this does not help, you probably have an obstruction somewhere in the hot supply line and a plumber may be needed unless you are handy. Good luck.
Jan 01, 2014 | American Standard Home
We installed an American Standard Soltura kitchen faucet and when we turned the water on, nothing comes out the spigot.. The water lines fill up, the line to the single spray head fills to the connector,...
Don't have a solution...but experiencing same problem on the HOT water side. Water lines were 4" too short, so I had to go back to Lowes to buy 2 more flex hoses and brass fittings (additional $25), and I have no hot water pressure, justa trickle.
Oct 27, 2013 | American Standard Plumbing
R120 Valve I have good pressure with the cold water but no pressure with hot water
I imagine you have the installation instructions since you just installed it. Your new shower handle has a hot limit safety stop. You can set this with a flat blade screwdriver. The safety stop is the red ring in the handle and all you need to do is pry the ring forward with the screw driver and rotate it clockwise to increase your hot water.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 12, 2011 | American Standard R120 Pressure-Balance...
The shower does not get hot so i took pressure balance unit apart and cleaned also took hot limit stop off .still not hot rest of sinks in house are hot and furnace right under shower,what do you think it...
When shower faucet apart make sure hot is getting 2 & coming out faucet ***. did you turn off stop integral w/ faucet or outgoing shut off valve on water heater.. May have rust or lime in small orifice leading to faucet ***. does your balancer/ piston move freely..good luck..
Mar 24, 2011 | American Standard Bath Faucet Ceramix...
Would like to increase water pressure
You will need the expertise of a Plumber, this is beyond the scope of this forum.
Jan 26, 2010 | American Standard 2000.502.002 Ceramix...
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
American Standard One Handle Shower Only Faucet 2000.501.295 Logo
461 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
