Question about LG (GCC-4240N) CD-RW/DVD-ROM (Combo) Burner
Cannot copy files, pictures ,or anything onto CD ROM. Tried different brand of blank CD (Maxell CD-R) and still cannot transfer any files. My other computer with the same drive will not recongnize the drive, so I cannot use it. Computer is Dell 4600C running XP. What's up?
    Guru:
  • 1,705 Answers
If a problem on 2 x pc's then its probably a drive issue.
Does it play CD/DVD's ?. If not you could try a CD lens cleaning disk, it may just need a good clean out.
As you're moving it between PC's then the IDE cable is probably connected properly.
My only other thought is that it is faulty, probably not worth repairing, you can get dual layer DVD/CD rw drives for under £15 on ebay.
Posted on Jan 02, 2011
  • LG Master
  • 27,725 Answers
You cant copy files/photos to a cd-rom you will have to either burn them to cdrw/dvdrw disc or copy them to a usb drive
click start open windows explorer navigate to your destination folder/memory stick then go to the information you want to back up select the information right click select copy then back to destination folder/memory stick select then right click select paste
or select the imformation hold the cursor on then drag it to the destination folder/memory stick and drop it into it
or select the imformation right click and send to the destination folder/memory stick
hope this helps
  • Brian Sullivan
    Brian Sullivan Jan 02, 2011
    on the other computer
    make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
    your drivers may have been corrupted or you might have a virus run your antivrus program
    you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
    you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
    control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
    select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
    hope this helps
    if this does not fix the problem it might be a registry problem
    Close all open programs
    Click on Start, Run, and type regedit and press Enter
    Click on the plus signs ( ) next to the following folders
    HKEY_LOCAL_MACHINE
    SYSTEM
    CurrentControlSet
    Control
    Class
    {4D36E965-E325-11CE-BFC1-08002BE10318}
    This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
    Upper Filters
    Lower Filters
    Upper Filters.bak
    Lower Filters.bak
    If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
    After deleting the keys, close the registry editor
    Reboot your computer
    Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
    hope this helps
Doesnt play DVD and Cd
I recently wanted to transfer holiday pictures from my laptop onto a blank disc, which I do by opening a window for 'My Pictures' and then opening 'My Computer' to get to the E drive (where my blank disc is). I click open a window for E drive (which shows it as empty) so now I have both windows open next to each other.
I then select the pictures I wish to transfer and then drag them over to the E drive window onto the blank disc. Then the computer transfers these pictures without a promlem and I am able to view the pictures now on the disc.
But recently it would not do this command. The 'cd writing wizard' would report to me that I needed to insert a blank disc which I had already placed in the tray. I tried different makes of discs, restarted my computer just in case it had a minor glitch, cleaned the laser head, tried different programs to see if anything had change without me knowing about it etc, etc, but to no avail. After much hair pulling, swearing and so on, I tried a program called 'Set program access and defaults' in 'all programs', clicked on 'add and remove program' and saw it was set on 'custom' as default (and will do so everytime I go into this program) then clicked on 'Microsoft Window'. I tried the above again and this time it transfered my pictures to the disc without a problem as it always use to.
I hope this might be of help.
Apr 20, 2010 | Televison & Video
Mp3 files will not burn
No imation brand is known for problems but maxell usually work great i suggest cleaning the cd burner try compressed air can spray out the cd burner with the door open you may have dust on the laser lens...
Feb 05, 2010 | Maxell CD-R 80 Minute 700MB Media...
Why cant I write onto my blank DVD disk I have windows XP and DVD R in my DELL writable drive.Im trying to copy about 1 gig of JPEGS onto the disk. The disc is MAXELL 4.75 GB DVD R. Im using windows XP....
It doesn't matter what name or brand the disc is. All it matters that it is a writable disc. If you had aldready written previous files on that DVD disc and then it was compiled, it wont write again. When the computer requests to compile a disc, say no, otherwise you wont be able to write more data on the same disc. The same goes if you have selected a CD to burn. There are 3 ways to do so. Try copy and paste, drag and drop the file to the DVD icon or CD icon, or right click on the file to be burned and select 'Send to...' choose the DVD drive, (D:), see what happens.
Sep 18, 2009 | Dell Computers & Internet
What did I do wrong? I copied doc files to a CD.
Is it a dvd-rom, dvd-rw, cd-rom, cd-rw?
What is the cd/dvd disk drive you are using?
(A dvd-rom, dvd-rw, cd-rom, cd-rw?)
This may be the problem.
Aug 22, 2009 | Compaq Computers & Internet
None
i would just rip it to your computer and transfer the files via a usb flash drive
Aug 12, 2009 | Video Game Consoles & Games
Problem with downloading photos mobile
first copy pics unto ur pc desktop. then right click to copy. again right click to send it to cd rom. then open my computer and right click on cd rom and writing to cd, but make sure that ur cd rom is a cd writer. okay?
Jun 17, 2009 | Lands Phones
Only records Lps and CDs, but not other cassettes
there are programs on the net that will copy from tape to cd via the computer if you have a cd writer on the pc hope this helps regards Jim
May 02, 2009 | Audio Players & Recorders
CD BURNING
This sounds like a dirty CD Drive, you can purchase a CD Drive Cleaner from most electronic stores that sale blank CD's. Maxell and Memorex are good blank CD brands. In addition make sure you are storing the CD's in a dry, dust free area, also make sure after using the CD Cleaner that there isn't any dust or debri. Keeping the drive free and clear of dirty will help with performance, if this does not help the last resort would be to replace the CD drive.
Mar 19, 2009 | Dell XPS 200 PC Desktop
Re-writable Maxell CD-RW - 700mb/80mins
hw could i put burn songs to a maxell cd r
it is not re writable
Mar 08, 2008 | Maxell CD-R 80 Minute 700MB Media...
D:\is not accessible incorrect function
- Please try this ... http://support.microsoft.com/default.aspx?scid=kb;EN-US;315350 Please revert back with the results
Apr 06, 2007 | Dell Dimension 8200 PC Desktop
LG (GCC-4240N) CD-RW/DVD-ROM (Combo) Burner Logo
103 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
