Question about Hitachi Nt50ae2 18 Gauge 34" To 2" Brad Nailer
M.My magazine cover will not close all the way even when there are no brads in it.
How to load brads into Stanly brad gun
Load in slider of nail magazine with the nails touching the bottom of the magazine.
Sep 28, 2014 | Tools & Hardware - Others
My nt50ae2 brad nailer jams in the magazine. the feeder rides on top of the nails.
This happens. The follower jumps over the nails and the magazine binds.
Step 1. Remove nails, unplug hose.
Step 2. Remove the bolt at the bottom of the magazine with a 2.5mm hex key.
Step 3. Remove the magazine while holding the nail follower in place to the magazine cover.
Step 4. Carefully remove the nail follower and gently extend the yellow warning indicator and follower spring.
Step 6. Inspect the nail follower. There should be 3 indentations that are stamped into nail follower face. This is the culprit.
Step 7. With a small punch, make these three indentations deeper.
Step 8. Assemble and test. Repeat if necessary.
Hope this helps.
Jul 28, 2012 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
TNT XAGD50 brad nailer is jammed
If the jam is bad enough you may just have to pull the 3 front magazine screws (metric allen screws) and the one in the rear that holds the magazine to the tool frame. That way you can pull the entire magazine off which will expose the nose area and you can remove the jammed nail.
Jul 28, 2012 | Sears TNT 3 gal Air Compressor with 2 in...
How do I load the 2 1/2 inches nails to my 16 ga porter cable finish nailer? How do I put the oil and what part of the gun?
You need to open the nail magazine and you just load one strip of nails at a time, then close the magazine. It will have a spring putting pressure on the nails, so it will have resistance on it and it will increase as you close it.
The oil gets dripped in the air hose connection on the gun before you connect the air. Make sure that this gun actually takes oil, some newer guns are oilless.
Hope this helps,Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 10, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
Help! My finishing nailer seems to have stopped driving the nail, period. It sounds like it is working but I am not sure if the hammer is even pulling back into the driver enough to actually drive...
It sounds like your gun has jammed. The fix isn't hard. First, though,make sure that your compressor is putting up sufficient pressure. Most of my jams happen when I drive brads and forget to turn the compressor back on! If the pressure is good, you'll need to check for a jammed brad. Disconnect the gun from the compressor. Pull back the slide and remove the brads from the magazine. At the front of the nailer, you'll find a cover, close to where the brads exit the gun. Open the cap and it will reveal a tab that will give you access to the nailing slide. Your gun probably came with allen wrenches, and they may be located on the gun, or in the case. Mine are along the slide, tucked in, and look like a part of the gun. You'll need an allen wrench (most likely) to remove the two allen screws that hold the cover assembly to the gun. Remove the screws, making note how the piece comes off. With the piece off you should be able to see where the brads come to the nailer from the magazine. Look for a hung up brad here. If you note a silvery piece of metal in front of the magazine, fear not, that is the hammer slide. The compressed air powers the slide down, peeling a brad from the magazine and driving it in. If necessary, you can gently press the slide back up. Try not to bend it. Locate the jammed brad(s) and wiggle them out of the gun to clear it. Sometimes it is easier to push them back into the magazine and shake them out. It takes a little finessing to get it right, but perservere. Reassembly is the reverse of the break down. Oil your gun daily. I put a few drops of oil into the air inlet at the gun before I connect the air line, and then drive a few brads into scrap wood.
Hope this gets you going on your project.
Best regards, --WoobieDog--
Jul 10, 2009 | Porter Cable Air Tools & Compressors
The door at the back of the staple gun won't close
You may have too many staples loaded in the magazine.
Jun 05, 2009 | Arrow No.ETF50PBN Extra Heavy Duty...
Driver cover "a" won't close
you may need to check if the driver blade is all the way up.first make sure you have the magizine open when you try to close the front latch.
May 21, 2009 | Porter Cable Cable BN125A Factory -...
Magazine cover for airy nailer
Airy no longer has a home base in the USA. E-bey might be your best option
Feb 23, 2009 | Tools & Hardware - Others
Hitachi Nt50ae2 18 Gauge 34" To 2" Brad Nailer Logo
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Roger Paull III
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
