Question about Maytag MER5775Q Electric Kitchen Range
Why can't I set oven temperature above 350? When I hit the "increase" button nothing happens.
  • Maytag Master
  • 1,902 Answers
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jan 03, 2011
GE Profile Oven temperature varies wildly
What is the model number of your unit?
Nov 19, 2012 | Ovens
My oven won't go past 350 degrees
If you have multiple elements it is possible that one may be burned out and limiting the high end of operation.. Check all to make sure that none is open and replace as necessary.
Check attached site for parts and prices. If you can get the part number it is possible for you to be able to get it on ebay for less money. No harm in checking. Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Ovens
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
T3 electric wall oven - Temperature set buttons
I had the same problem. The entire control panel had to be replaced. That included the display, keypad and all the hardware behind it.. it's one integrated unit. Luckily I had the extended warranty, otherwise it would have cost close to $400.
Jan 20, 2008 | Maytag 30 in. Electric Single Wall Oven...
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag MER5775Q Electric Kitchen Range Logo
67 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
