Question about Maytag MDB6709AW Builtin Dishwasher
Why was this dishwasher recalled ? model no. mdb6709aww1 I has alot of problem with this washer.To many to write about. I need to talk to someone.
2 Suggested Answers
  • 30 Answers
SOURCE: had a recall on part on my dishwasher. Someone
YOU NEED TO CALL THEM BACK OUT ASAP. If it is something that they did they are responsible for all damages. DO NOT touch anything such as trying to fix it yourself at this time. They can consider it to be tampered with and there would be NO TELLING if it was a service/install error or customer tamper. Call them first. If anything shut the water off using the shut off valve and shut down the power to it. It could be something as simple as a hose that got jiggled around when the tech was replacing that part.
Posted on May 03, 2009
Need info on recall
as far as I can find out all models starting with wa48j777oaw is on a recall...you will to ring up who ever you bought the washer off.
and they should put you in touch with the recall center.
Nov 06, 2016 | Washing Machines
Dishwasher does not drain
First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire!  Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment.  We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service!  Hope this helps!
Oct 03, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Bosh dishwasher modle shu330cu not draining or lighting up
Jul 12, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Dishwasher won't power on- no lights. My husband just cleaned out the appliance- could he have knocked something loose?
Hello, welcome to Fixya. When you state your "husband just cleaned out the appliance" what do mean exactly. I would suspect a poor line connection at the junction box where the power enters the dishwasher, or a broken wire in the door panel at the point it bends as the door opens & closes is common...based on what you've described. Let me know by posting a reply what you find and what you meant. **Make sure the breaker is OFF before attempting any repairs** I'll try and assist you through a diagnosis and repair if need be. Good luck macmarkus :)
Jul 07, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a bosch shu3002uc that is leaking at the bottom of the door. I have to put sponges on the floor to catch the water. What should i do?
Check the levelness of the dishwash. Is it level.
Check the seal around the contact surface of the door and the washer opening. Are there any cuts or gaps?
Apr 25, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
I need the hose adaptor that is attached to the
try AppliancePartsPro.com You will need your make / model #
Feb 26, 2010 | Dishwashers
Frigidaire dishwasher model pdl4375rfc2 serial# th80537081 door weaks aat lower right corner user less than 6 months is there a recall on this model
if unit is less than a year old . call for service 1-888-203-1389. this unit has a one yr. warranty from the manufacture. recalls are usually not given on appliances unless it is a safety issue. however i have repaired alot of these under warranty for your same complaint. their is a splash kit u can get that goes on each corner of the bottom of the inside of dishwasher that will stop it from leaking, roughly 10-20.00 dollars depending on who u purchase it from .hope this helps out.
Oct 06, 2009 | Frigidaire PLD4375RFC Dishwasher
Dishwasher leaks, is there a recall on this model,mdb7100awb
if the dishwasher is leaking water there is no recall on that. the recall i believe you are talking about would be for the rinse aide leaking in the door. you should contact maytag to see about getting the new kit installed on your dishwasher and you may get your leak fixed for free since the kit comes with the door seal.
You can contact maytag at (800) 675-0535 do not wait and do not use the dishwasher. you will need the model number and serial number off your machine when you call. it is located near the door seal on the tub.
Jan 03, 2009 | Maytag MDB7100AWB Dishwasher
Bosch dishwasher will not cycle. Water in base
Dec 22, 2008 | Dishwashers
Maytag MDB6709AW Builtin Dishwasher Logo
404 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
