posted by JaneKatherin on Jul 09, 2008
i have a mitsubishi meddalion hd1080.
i turn the power on and it stays on for like 3 seconds, then goes off.
the green led light is lit when i turn it on, but goes back off when the tv turns off.
i was wondering if you knew what the problem was.
If you need more info, i'll be sure to get it to you, if it will get the problem fixed!
Thanks!
Solution #1
posted on Jul 09, 2008
The set is going into shutdown because a problem has been detected inside. This prevents further damage. It could be anything from a shorted horizontal output transistor to a defective convergence IC. Without examining the board and taking measurements inside, it will be difficult to near impossible to diagnose this remotely. I would suggest that you invest in a detailed repair estimate that shouldn't cost more than $100 and report the results here. With that info, we should be able to walk you through the actual repair.
Dan
Dan
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Projection Televisions
Email this problem
Email this problem
This Problem Also Relates To:
GE 46GW947 46 in. Rear Projection Television
GE D52GW12 52 in. Rear Projection HDTV-Ready Television
Panasonic PT-47WX53 47 in. Rear Projection HDTV Television
Panasonic PT-50LC13 50 in. Rear Projection HDTV Television
Panasonic PT-52LCX66 Television
Sony Grand WEGA KDF-60XS955 60 in. Rear Projection HDTV Television
Sony KP-43HT20 43 in. Rear Projection HDTV-Ready Television
Can you Help with these Projection Televisions problems?
RCA Scenium D40W20 40 in. Rear Projection...
Red Lines remain on screen
Red Lines appear on Screen and... Answer This...
Repair Service
Find Projection TV Repairman Near You:
