How do I make my videos run faster?They are more than one or two minutes between shots now. Also, how do I turn on my speakers. I have silence now.
  • kjackkrebs55 Jul 09, 2008
    I used to get sound,but I never got speedup video
    Novelist:
  • 126 Answers
Seems that you may need to go to windows update and get the required drivers for your system www.windowsupdate.com go there and get all avail updates not just the security patches but also the custom updates and the hardware updates it will all be there . also u said that the same computer played these videos once opon a time so something went wrong somewhere .so im thinking you picked up a bug of somesort go to www.iobit.com and download advanced windows care for free not the pro version as its a 30 day trial home version is plenty run this program and follow instructions and it will do a registry clean up as well as a spyware sweep
good luck also see that you have the proper direct x 9.0c i think is the latest one
Posted on Jul 09, 2008
  • 4,472 Answers
Can you provide more detail to your problem? What do you mean by speeding up the video? Do you still have a problem with sound? What is the model of your computer? What operating system are you running?
Thanks,
Lee
    Brigadier General:
  • 6,966 Answers
Assuming that you have all the necessary video codes and the video player, it would be your hardware requirements that may be causing the slow response. This would either be your PC's memory, processor and/or video card.
If you were able to watch the videos before with no problems, then perhaps, your PC may be running several other programs in the background that is using most of your memory leaving very little for the video. Try removing some of those unnecessary programs in your Startup as well as in "msconfig/startup".
You may also want to check on possible virus and malwares.
As to your audio, the easy way is to check if it is muted or not. Additionally, you may want to check in your Device Manager if the drivers are installed with no yellow or red marks.
Additional information on your PC's hardware specs, Operating System and video player software would be helpful in further diagnosis.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 13,433 Answers
Drivers must be missing, id guess you need video and sound drivers?
  • Ekse Jul 09, 2008
    I will need to know the brand and model of the pc to get you the drivers required.
    You can send me a message with reply / comment or ask me.
    note that reposting / requesting more assistance will reject my support.
Why do the TV speakers not silence when the headphone port is used?
Headphone socket connection fault. Not cuts off the internal speaker. Replace the socket with an identical one.
Electro help
Aug 19, 2014 | Hitachi Televison & Video
Squeaking noise from rear while driving
2 options
the brake pads are worn past safe and the small;; spring is running on the disc rotor , or there is a failing cv joint making the noise
Jul 06, 2017 | 2003 Chevrolet Avalanche
After my girl tried to turn it on (God know what button the pressed) I can only hear a very low sound from the speakers, even when the volume is at max. speakers are connected properly, the input is in...
I wonder if she pressed the mute button as it is used to silence the speakers when required.. Look for a button with the sign that looks like a speaker with a cross onit
Aug 05, 2013 | Sony DAV-DZ100 System
Suddenly lost sound
On my system, there a button to turn off the amplifier and an additional button for silencing the speakers. Did the speaker button get turned off?Will your system work with headphones?
Jan 13, 2012 | Philips Audio Players & Recorders
No sound on my radio anymore, display gives radiostation but no speakersound; my phone , video still working! Who can help me out?
Check on the front panel of this receiver for a speaker switch or button. If there is one there, which there usually is.. PUSH IT (or them) This problem has happened to the most knowledgeable professionals in the sound business. Give it a shot.
If there is any sound coming from any speakers, it is not the speaker switch.
Sometimes a frayed wire shorting out can shut down the sound on a receiver. It's a because of the protection circuit in it.
There is a form of automatic muting on most FM receivers. If the station is too weak or the antenna is not connected or working properly, you can get silence for the unit.
Hope this helps,
Best,
Mark
Dec 30, 2010 | Denon DRA-455 Receiver
Problem(s) Description(s): Initially intermittent output with good audio quality on all four speakers/channels,( five minutes of output then maybe two minutes of silence) then no output at all on all four...
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 16, 2010 | Rockford Fosgate Punch 600a4 Car Audio...
Point of impact changes with every shot
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Jul 30, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Sound doesn't turn on after a few minutes!
hey you must be using win xp home edition sp2 - had similiar probs!
either do all the automatic updates available from microsoft.com
or install win2000, if it is an older model u use this might do, but ensure you got the right drivers for all your components and made a backup of all your personal data.
Apr 21, 2009 | Computers & Internet
Adobe flash player doesn't play videos on the internet
try to pause the video and then let it load for a few minutes before you play it again. it may be a bandwidth problem
Dec 28, 2008 | Computers & Internet
Intermittent Sound from Home theatre system
confirm good wiring condition of celling speakers and disconnect it and connect it again-keep good ventilation around.
May 08, 2007 | Sony STR-DE598 Receiver
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
