Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Starter makes noise but will not turn engine - Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
    Problem Solver:
  • 4 Answers
Check the solenoid. or replace starter
Posted on Jan 03, 2011
1999 Pontiac Sunfire 5 speed won't start. Replaced spark plugs and checked ignition coil (fine). Sounds like it wants to turn over but makes a "whining" noise. Please assist. Thank you!
Is the engine turning over with the key in the start position? If the engine is not spinning over and you hear a whining noise, the starter is not engaging the flywheel. If the engine is turning over with the starter engaged, the engine has most likely jumped time that creates low or no compression which results in the whining noise.
Mar 03, 2015 | Pontiac Cars & Trucks
Turn key just a clicking noise. Lights come on. Check engine light on
A weak battery will make the lights come on & energize the solenoid for the starter, but the battery is too weak to make the starter motor turn. Checking the battery would be first, the solenoid second.
Oct 14, 2014 | 2003 Chevrolet TrailBlazer
Replace starter
two things can happen
first the starter will spin but don't trow the Bendix (shaft) to engage with the flex plate
second flex plate have worn spot and the starter spin on dead spot
turn the engine with hand little and start again.
if the starter work normal the engine will turn.
if nothing happen the starter is bad
Apr 01, 2014 | 2002 Toyota Camry
Starter motor noise
Sounds like the starter bearing is dried out,(very common on VW) you cannot lubricate them, only way to fix the noise is to replace the starter. I have seen VW starters make this noise for years and still keep working, so it is up to you if you want to change the starter, noise bothers you to much, then you can change it, it will not cause any damage to your engine.
Feb 10, 2014 | Volkswagen Polo Cars & Trucks
Tried to start car and it was starting to crank over then started getting this clicking noise. thought it was the battery connection, I cleaned the cables and posts and still got clicking noise when...
celunoid ?? SOLENOID ! Could be starter , test ! VOLTAGE DROP TESTING .
Starter Voltage Drop
What size engine ???
Starter Motor, 4.6L C1020
Lower right side of engine
Starter Motor, 5.4L C1020
Starter Motor Relay, 4.6L C166
Right rear of engine compartment
C167
Starter Motor Relay, 5.4L C166
C167
Jun 23, 2017 | 1999 Lincoln Navigator
I have a 93 Mitsubishi 3000 gt and when I try to start it it makes a clicking noise .. whats the issue ?
Is the starter making the noise, or the engine ?
Do you have power going to the starter ? Can you turn the engine crank by hand ?
Jun 30, 2013 | Cars & Trucks
Car won't start and starter is only making clunking noise
You can take out the spark plugs, keep track of your spark plug wire order, try to crank it over see if the engine turns over.
Check voltage on your new battery, some need to charge when new.
check for corrosion on the battery and starter cables.
Sep 29, 2012 | 1991 Saturn SL1
How to tell if your starter is bad
WHEN STARTER GOING BAD.SOME TIMES YOU TURN IGNITION NO SOUND FROM STARTER.WHEN STARTER GO BAD IT WILL TURN ENGINE OVER VERY SLOWLY LIKE YOU HAVING A WEAK BATTERY.BAD STARTER SOLENOID MAKE CLICKING NOISE ENGINE WONT CRANK.BAD STARTER WILL MAKE NOISEY GRINDING NOISE IF DRIVE PINION GEAR DAMAGED.
Aug 28, 2010 | 2006 Dodge Charger
Starter makes whinning noise on 97 camarro .battery is fully charged and starter tested positive at parts store.
Make sure that starter wears a condom.
If you meant that the starter makes a high-pitched whine but does not turn the engine, that starter is bad. More specifically, its drive (the "Bendix") is bad.
If the starter makes a screeching noise as it turns the engine, like it is working too hard and is irritated about the situation, you need to shim the starter. There are shims available at the parts store that fit around the mounting bolts, between the starter and the block. They are used to ensure that the starter drive gear teeth are not too close to the ring gear. If they are too close, the starter has to work much harder as it forces the teeth to mesh.
If you meant that the starter makes a whining noise for a short while after you start the engine, don't worry. Many starters do that.
If you meant that the starter makes a loud whine constantly after you have started the engine, it is staying engaged. It is either bad and that is the source of the problem, or there is another problem (like incorrect shimming) that caused it to stay engaged, and it is now bad. The same gear reduction that allows a small electric motor to spin a big heavy engine can work in reverse if the one-way clutch in the starter drive goes bad, and the high speeds that the starter guts would be subjected to if this happened would lead to self-destruction.
Nov 16, 2009 | 1997 Chevrolet Blazer
Starter makes weird noise dosent turn over
Starter drive not engaging fully . Sticky or worn, but don't think changing thermostat had anything to do with it. Try having starter drive inspected & lubed if possible , but you may end up with new starter.
Dec 22, 2008 | 1998 Pontiac Sunfire
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
129 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
