Question about Altec Lansing VS2221 Computer Speakers
I need to clean the volume control of my Altec Lansing VS 2221 speaker, but when I try to open the enclosure, after removing the two screws, the back only comes off about 1.5 inches from the end the screws are on, then it seems that either the panel is held in with glue of tabs, but won't come off any more. if I force it more I'm almost certain it will break! Is there some trick to opening up the enclosure? By the way, I cleaned the pot on another set of speakers and they work like new again. The AL speakers are really really bad now (lots of noise when using the volume control) and also need cleaning to restore proper operation. Thanks for your help.
Smooth_Gecko
  • 125 Answers
SOURCE: MX5020 Noisy
Try to blow it out with compressed air. Then, with the speakers turned off, turn the volume knob to full volume and back as quickly as you can (without damaging the switch) three or four times. This should take about one second for three movements. Undertake this at your own risk. Turn them on and see if it has helped. Do not just keep doing this. if it doesn't help immediately stop. if it does help, repeat blowing out and repeat the knob turning, once.
Posted on Mar 06, 2007
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: One speaker not working
I called Altec Lansing Technical Support:
Altec Lansing
535 Route 6 & 209
Milford, Pennsylvania 18337-0277
T. 866-570-5702
T. 570-296-4434
F. 570-296-6887
They stated that the case is not made to be opened (Great Design...NOT!) They suggested I remove the sub-woofer cable and clean the pins with alcohol. Of course, you should remove the AC plug first.
One other suggestion I would make as a last resort, for this and other problems. With the unit unplugged, pull off the Volume Control Knob, and the sfx knobs.  Spray electrical contact cleaner in the openings, and hope it reaches the dirty areas.
Make sure all the cleaner has evaporated before reconnecting the unit.
Good Luck
Posted on Feb 13, 2008
SOURCE: output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Posted on Feb 26, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
How to take apart altec lansing speakers to clean volume control
You do not take speakers apart to clean a volume control Do you know what you are talking about? I do not think so.
Mar 31, 2017 | Altec Lansing Audio Players & Recorders
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at maurya.mohit07@gmail.com
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
My problem is when i turn up the volume of the speaker it will just turn off. tnx
Your altec lansing need to be open, because it has a loss connection on the power supply part of its circuit board. that is why when you turn up the volume it turns off because it produces vibration enough to shake the circuit board which has a loss connection.
1. Prepare the following tools:
* soldering gun/iron / soldering lead and a magnifying glass
* open your altec lansing cover enough to see the circuit board
2. Try to examine the leads on the circuit board, try to share some of the spare parts make sure it is not plug to live outlet to avoid electric shock.
3. if you see some spare parts shaking try to resolder it.
4. Then close back the cover.
5. Then test your altec lansing
Jul 11, 2011 | Altec Lansing ACS 45.1 Computer Speakers
I want to open my speaker (volume control, bass control) but I couldn't find any screw.
look underneath some stickers sometimes they hide them under them. Otherwise try to take off anything that looks removable.
Feb 05, 2011 | Altec Lansing VS4121 Computer Speakers
Static when I turn on speakers or adjust volume
The problem is that the switch/volume control is dirty.
This is what I have done.
Dismantling Altec Lansing VS 2221 speakers to clean the switch/volume control
Tools: a medium Phillips screwdriver, a craft knife & a can of CO contact cleaner & extension.
1. Remove switch/volume control knob by pulling it off
2. Pull out the base for the stand if attached
3. Unscrew the 2 screws beside the wires
4. Remove the front gauze by prising it out from one of the bottom corners. Keep the gauze straight as it will need to be put back from the bottom to the top.
5. Remove the 2 screws at the top and the 4 long screws holding the speaker. The back will come apart from the front and sides. If it has been glued then use the craft knife to carefully cut the back away from the sides and/or prise it away with a little pressure on the sides.
6. Attach the extension to the can of contact cleaner.
7. Lift the circuit board out and squirt only the switch/volume control. Ensure you squirt the shaft and the internal parts of the switch/volume control. Turn the shaft a few times.
8. Allow the contact cleaner at least 1 hour to dry.
9. Test the speakers. If the noise is still there then repeat steps 6-9.
10. To assemble the speaker do the steps 1-5 in the opposite order.
I hope this is helpful
Jan 26, 2010 | Altec Lansing VS2221 Computer Speakers
jjohnmith
First things first:
1) check your speaker for good connector, and all is working is playing fine.
2) check if your warranty covers one SPK. or RMS
other than that ,
Good Luck
Feb 01, 2008 | Altec Lansing VS2121 Computer Speakers
Altec Lansing 4.1 ADA880
if you are a technically skilled person
simply clean all the IC(chip) leads, by using a blower or using a painting small brush
the dust come in contact with the other pins that make this problem
Jan 23, 2008 | Altec Lansing ADA 885 Computer Speakers
MX5020 Noisy
Jan 22, 2007 | Altec Lansing MX5020 Computer Speakers
Altec Lansing VS2221 Computer Speakers Logo
124 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
