Question about Frigidaire Dryers
Tub on dryer will not turn unless it is spinned by hand several ltimes. When the button is clicked to turn it on, there is a noise that sounds like it is trying to connect, and when the turn is turned by hand several times, it does come on.
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Whirlpool dryer awz123 make loud noise
sounds like a bad tub wheel that the drum rides on ,just take the front off look in the back ,there are two wheels that the tub rides on ,go to your Sears parts dept with the model number ,get the part easy job
Jan 15, 2013 | Dryers
Dryer tub loud, can turn tub by hand
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 27, 2011 | Amana DLE330RAW Electric Dryer
During the spin cycle there is a very loud knocking noise,
Could be the spider arms are broken. You can confirm this by turning the tub by hand, if you hear any kind of thumping sound as you turn the tub, then the spider is broken. The spider is the support arms that hold the wash tub to the drive shaft. It's very expensive to repair.
If there is no thumping sound when you turn the drum, it could be that one of the supports or spring is broken. Hope this helps.
Jul 23, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
My dryer heats up but does not tumble. I replaced
Sounds like worn tub back bearing.
take the belt off and spin the tub by hand to see if it is binding.
check that the pulley isnt loose on the tub back and also the motor pulley, feel if the motor spins free.
Finally check the tub itself for objects poking through or lodged in the outer tank.
Good luck
Mar 18, 2010 | Dryers
Tub sounds like it is grinding
could be worn tub back bearings.
check by lifting the drum up and down to see if there is
excessive play. you can also check this with the tub back belt off.the spin it by hand accertain that the noise
is coming from the bearings.
Good luck
Feb 22, 2010 | Dryers
Bosch WTMC3500UC Gas Dryer Dryer...as it is turning makes LOUD clanging banging noise. Will make the noise when turned by hand does not make the noise when tuned by hand in the other direction.
heatman101
gkjlgkj
Feb 15, 2010 | Bosch WTMC3500UC Gas Dryer
I have a Frigidaire Electric Dryer FEQ1452HS 5.8cycls (front loader). Purchased in December 2008. The dryer has never dried the clothes very well, but now I have a bigger problem. When dryer is turned, it...
Sounds as if something has the tub locked. Remove the top of dryer so you can get look at the tub. You may have to remove the tub to locate the problem.
Apr 07, 2009 | Frigidaire Dryers
Kenmore dryer will not turn on
Sounds like a classic broken Belt. You'll have to take the front or top off to gain access to the belt and it is wrapped around the TUB. If you can pull it up and down with no problems its the belt or the idler tentioner that keeps the belt tight.
Possibly its also the tub rolers or bearings but if you can push the tub from the inside by hand you will know if its in this area or not. If it turns freely then the belts off or broke cause when its on and tight you anct make it move very far. Important not to make the tub turn back wards too far especially if its tough to move. If its loose to move then either way usually dosnt hurt anything.
Mar 02, 2009 | Kenmore 659 Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
