Question about Maytag MAH6700AWW Neptune Front-Load Washer
I want to check the drain pump on a Maytag MAH6700 Nepturne. How do I access the pump, from the back? One internet site suggests removing the door and front panel but I am not having luck even getting the door off this model. Perhaps earlier models had front access panels and later ones don't???
    President:
  • 3,113 Answers
Posted on Jan 02, 2011
Testimonial: "Schematics helped me determine how to access washer pump from rear not by removing the door and front panel as other internet sites suggested. Thanks!"
Softner will not despence mah6700aww
Posted on Sep 09, 2011
I have a maytag Neptune washer and it does not drain water, why is that?
the drain pump is plugged with foreign materials,you can access the sloped front "MAH" series from the front by removind 4 screws around the door perimeter and removing front panel by swinging outward toward you,others by removing rear access panel on the back side of the machine
May 11, 2012 | Maytag Washing Machines
My washer stopped working and is displaying the code nd, what does this mean?
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Maytag NFW7200TW Front Load Washer
My machine wont spin out
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer wont spin out displays 5d code
Good luck.
Jan 11, 2011 | Maytag Bravos MTW6600T Top Load Washer
It starts to spin slow then quits.
Good luck.
Jan 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Washer
follow the below procedures on how to Troubleshoot a Front Load Washer That Won't Spin or Drain;
1. Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
2. Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
3. Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
4. Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
5. Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
6. Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
7. Close the door completely. The washer will not operate if the door is not securely closed.
Good luck.
Jan 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
Error code ND cannot get door open -soggy clothes inside
The "nd" indicates "no drain" and would usually mean something is wrong with the drain pump.
I would suggest checking the drain pump for obstructions or if it hums or tries to run.
Most likely there is a piece of clothing in the pump or it's bad and needs to be replaced.
The wrong soap might cause excessive suds and create a drain problem.
The image below will help you remove the front panel to access the pump.
Jan 10, 2011 | Maytag MAH8700A Front Load Washer
How do i get to the drainage hose in back of neptune FAV6800AWW?
You have to remove the front cover from the machine.
Do you have the FAV6800A/FAV9800A Service Manual?
I'll see if this site can let me post a pic of the wash tub removed. In this pic you can see the Drain Pump/Pressure Switch and drain line on the right side of the machine. There is no side or rear panel access.
What is the issue? Won't drain?
I would suggest you Google "Maytag neptune FAV6800aww wont spin" this forum has a Sticky for Maytag FAV6800A and FAV9800A machines and you can get the Service Manual from this site. I feel it's a better DIY site.
OK let me see if I can attach a pic;
Jan 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Where is the drain pump (and how do you access it on the Neptune MAH6700 front load washer?
i have maytag neptune mah6700 and dosent rince good in the end of each wash the cloths steell to mutch water in the cloths dosent rince it good i thing the speed of the spin not that strong and the motor its very good but i thing is someone played with the fron the code and i dont have the manual to check those code
Oct 03, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Mah6700. Not filling/ draining simutaneously=NO CYCLE
try to blow through the pressure switch hose back into the tub and if you have a piece of same size hose when you disconnect the tube to blow through it use you spare hose connect to the pressure switch and blow lightly do you here a light clicking when you blow into it if not pressure switch is more than likely failed when you done tested air restrictions ........RECONNECT THE TUBE TO THE PRESSURE SWITCH.....
Aug 25, 2009 | Maytag Washing Machines
Maytag MAH6700AWW Neptune Front-Load Washer Logo
669 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
