Question about Ryobi Three Trimmer Combo
I have a Ryobi SS30 string trimmer with the attatchments. It has never run well since purchased several years ago. At best it will start and I have to run it in the 2nd choke position and hold the trigger just right. At worst it will not start. The gas has the mix, is old but has stabilizer. This is the same gas that works just fine in my mower (w/o the mix). I use for my homne on average 1 or so hours a month
    Genius:
  • 1,267 Answers
One thing that I have found about 2 cycle engines is that to leave fuel in them over the winter months is asking for trouble, even if they have stabil in them. The reason for this is the alcohol that the government mandates for all gasoline. That alcohol is very hydroscopic and sucks water ito the mixture creating a goo that blocks the needle valve in the carburator, as well as seals the little flapper valves that allow fuel flow. it also blocks the strainer in the tankblocking fuel flow. You can first try this. Remove all of the fuel from the tank. take the top off of the carb and spray a generous amount of carb cleaner down in the top of the carb. replace the top of the carb. Refill the tank with a new mixture of oil and gas (don't use gas that has sat longer than 3 months.) Add a little bit of SeaFoam or any other additive to the mixture. Start/Try and run the machine untill all the fuel has burned off in the machine. refillagain and see if it did any good. If not then you may have to clean the carb and replace the flappers in the carb, as well as fish the strainer out of the tank and clean it. That alcohol sure causes a mess. When you store the machine for the winter, burn off all of the fuel and let the machine be empty for the winter.
Posted on Jan 02, 2011
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
How do I remove the carburaetor locks on Ryobi ss30 seedeater I am a beginner lady learning to fix my own stuff
Remove carb mounting bolts. Carb obsolete not available. This may help: http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Dec 22, 2015 | Ryobi Garden
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
Manual for ss30 string trimmer
http://dl.owneriq.net/9/9e64612c-7e9e-49b8-b7af-195ff11f1bef.pdf
Jul 02, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
How do i take a part ryobi cs30 trimmer to replace the pull cord?
Here's a link to step-by-step and a video for a Ryobi SS30 string trimmer. I do not believe there are many (if any) differences between those instructions and you trimmer.
Aug 18, 2010 | Ryobi Garden
My Ryobia SS30 SS# ATJ0830439,weed eater, the pull cord will not retract please help Thank You Gail
http://www.ereplacementparts.com/ryobi-ss30-ry30002-string-trimmer-parts-c-7931_15633_15651.html
This is a parts site for you with a schematic so you can see what is going on. I think your return spring is either broken or out of it's keeper. Check it out. hope this helps.
Apr 28, 2010 | Ryobi Garden
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
Engine runs but no power to the head
It could be simple. Sounds like the drive cable came loose or broke. You could get an estimate from a repair shop -- probably not terribly expensive.
May 08, 2009 | Garden
Ryobi Three Trimmer Combo  Logo
603 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
