Question about Maytag Atlantis MAV6000 Top Load Washer
My Maytag Atlantis washer is making a clunking sound during the agitate cycle. Do I need to replace the thrust washer?
Coldcut
  • 1554 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
The belt is slipping and needs replaced.
Posted on Jan 26, 2008
huuum
  • 750 Answers
SOURCE: Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
huuum
  • 750 Answers
SOURCE: maytag atlantis washer mav-31
Hello
Welcome to fixya.
Is t your washer cleaning the clothes and operating fine other than the noise?
If so do not spend any money on it unless it breaks or does not operate!
"If its not broken do not fix it!"
I know this is not the what you wan to hear!
I have a telephone number of the consumer affairs of for maytag that's hard to find!
If you call them thay will demand that thier servicers find and remedy the problem or swap it out for you!.
Even if it is past warranty.
I'm not at work for another couple of hours.
When I get there I'll give you the 800 number for Whirlpool (They now own Maytag) Consumer affairs and you can cal Monday!
I do this frequently for my customers!
Everyone knows,
"It's easyier to keep the customers you have than find new ones"
But no matter what happens,you have no need to pay the repair persons child's college tuition!
You have your own needs!.
How much did you spend on this machine even though it did wash and perform?
Noise is not broken or failure.
I had a Maytag Neptune that did this for 6 years and I fixed 2 other problem unrelated .
Then on the third break down I dumped it in the trash and bought myself a Speed Queen Commercial
washer that will last me 25 years for half the price of the $999.00 Maytag Neptune.
When I complained to my father about the noises in our family car he used to tell me,
turn on the radio.
Thank you
SOURCE: grouling noise in the spin cycle
First, check the belt (located in the bottom of the unit) and if it shows signs of wear (black dust) and shiny sides on belt and black marks on the motor, transmission, and water pump pulleys - replace the belt. The motor is spring loaded and acts as the tensioner up to a point of too much wear on the belt.
You will need to tilt the washer about 45 degrees and prop it to keep it from going all the way over (just makes it more difficult to right it later). Pop the belt off by rotating it while pulling the belt off the edge of the transmission (larger) pulley. Again, the motor pulley is spring loaded and will flex appropriately. Reverse the process with installation of a new (exact replacement part number).
If this doesn't fix the problem, you may have to call the Maytag Repairman. They would have replaced the belt anyway and would probably charge $50 + for the belt and installation.
Posted on Dec 29, 2008
appldoctom
  • 311 Answers
SOURCE: Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Posted on Jan 03, 2009
Should water back up into the tub upon spin completion on maytag atlantis
No, If water is coming back, the sewer is cloged up or is a big posibility that the washers transmission is not spenning at all. it may sound like is agitating during the wash and spinning during the rinse. To check it, put soap inside the drum if it doesn't get disolved after the cycle is done. The transmission needs to be replace. Is costly you may want to shop for a new one.
Jul 19, 2014 | Maytag Atlantis MAV6000 Top Load Washer
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Won't spin
Sounds to me, your belt is slipping. The motor tensions the belt with springs. The motor slides in grooves to keep the belt tensioned. These grooves get gooked up with dust, dirt, rust, slime, etc. Move the motor back and forth a few time to clean the grooves. Also spray some lubricant on it to help clean it and make it slide freely. Be sure both sides slide back and forth in their groove. After doing this, your belt should stay tensioned enough not to slip during the spin cycle. No tools needed and even the average moron could do it. Hope this helped.
Sep 30, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
