It will turn on for about three seconds then turn off and the red light starts to flash
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Jan 02, 2011
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Well when I turn on my xbox 360 the third part flashes red.
hello.
CAUSE The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. Please read the letter that discusses warranty changes for three flashing red light hardware failures.
MORE INFORMATION
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue:
1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles:
906101 Xbox 360: The power supply light is red 906102 Xbox 360: The power supply light is orange 906103 Xbox 360: The power supply light is not illuminated
2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again. If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support, and then click Console Repair in the upper-right section of the Web page.
Note: The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact for information about how to do this.
APPLIES TO
* Microsoft XBox 360 Video Game System
* Microsoft Xbox 360 Hard Drive (20 GB)
* Microsoft Xbox
Apr 27, 2009 | Microsoft Xbox 360 Console
Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
RED RING WHEN TURNED ON OFF FOR A WEEK
Nov 26, 2008 | Microsoft Xbox 360 Console
Three red lights
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE: The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION: If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 08, 2008 | Video Game Consoles & Games
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
Sep 05, 2008 | Video Game Consoles & Games
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
