Question about Frigidaire FEF336BC Electric Kitchen Range
I want to unlock my oven door - Frigidaire FEF336BC Electric Kitchen Range
  • 1,531 Answers
You can press the clear/off key for about three two five seconds
Posted on Jan 02, 2011
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Oven wont work unlock door meesage keeps flashing door unlocked
    The model number would have helped us give you specific advice, but without it we'll give you generic advice and say it may be a door switch issue.
    See our help file on door switches here.
    Jan 16, 2013 | GE Microwave Ovens
    Cannot unlock oven door
  • Here it is!
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    How to unlock the hinge on an Ariston Oven Door with door off
    To Unlock the hinge on an Ariston Oven Door
    Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
    With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
    Fitting the Oven Door
    Fit the door to the oven with the metal receivers in the slots on the oven.
    Once the receivers are in the slot, fully open the door (in a downward position).
    Flip the U shaped pieces over to lock the hinges.
    May 17, 2010 | Ovens
    Oven door won't unlock
    kenmore selfcleaning oven door will not unlock code f9 appears in window
    Jan 03, 2010 | Ovens
    HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
    In order to unlock the oven you need to perform the following:
    Thank you for contacting Fixya.com
    Aug 07, 2009 | De Dietrich Ovens
    Can't Unlock oven doors after "self-Clean" maytag double oven
    I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board.
    Dec 22, 2008 | Maytag Kitchen Ranges
    I had this same issue and consulted the owner's manual. Once on self clean it takes up to 3-4 hours for it to automatically unlock. It is a built in safety feature of the oven.
    Jun 21, 2008 | Kenmore 46123 Stainless Steel Electric...
    Oven door will not unlock
    try pushing in on the oven door and push cancel. you should hear the unlock motor unlock the oven door
    Apr 10, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
    Frigidaire FEF336BC Electric Kitchen Range Logo
    260 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Ismael Rodriguez...
    Paul Carew
    Justin Duby
    Justin Duby
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
