Question about Maytag Centennial MVWC700V Washer
I'm not sure this is the model that i have. but my problem is this i went to use my top load machine, after the water filled to the desired level it did not go into the wash cycle my machine is full of water now how can resolve this problem
    President:
  • 3,113 Answers
Push down on lid or lid switch.
Posted on Jan 02, 2011
How do i fix washing machine
Reset level selector by turning to low and back up to desired
Try hot and try cold. See if either one will fill/partial fill.
Try rinse
Try spin only.
No rinse no spin Check timer electrical
If spin but no water hot/cold look for defective level sensor.
Dec 07, 2015 | Kenmore 24032\24036 Top Load Washer
My ge top load washer will not stop filling up with water
The water level switch shuts the water off when it gets to the desired amount. Also change the water level to low and see if it stops at different level.
Jan 06, 2015 | GE Washing Machines
Water flowing through outlet pipe before washing. does not seem to fill tub properly
Make sure that the outlet pipe is higher than the top of the desired water level, preverably level with the top of the machine. Otherwise it will run out to the level of the pipe.
Jan 28, 2011 | Speed Queen AWS44NW Top Load Washer
Washer fills with water and then stops
the water pressure switch that fills the machine to the desired level has electrical contacts and when the water gets so full per the selector switch it closes these contacts to start the wash cycle,these contacts are defective,replace this switch,its on the control panel
Jan 27, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My washing machine wont stop filling up with
well the part that tells the water to stop running in is the pressure switch if the water valve is working properly so disconnect the power and if the water continues to run in it is the water valve just replace it
Apr 26, 2010 | Washing Machines
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Pav 2300 water over fills even on a mini load past top
check the pressure line from the tub to the water level switch and make sure that it does not have a hole or crack in it if the hose is ok then the water level switch is bad
Apr 19, 2008 | Maytag PAV2300 Top Load Washer
Water won't fill up all the way up on large cycle, I must manually fill to desired level then shut off
change your pressure switch its the one where you select your water fill level back out the two screws on each side of the control panel back or front pull it slightly forward then tilt it back should be a gold dome with a plastic hose and three wires
Feb 26, 2008 | Kenmore 22422 Top Load Washer
Washer filling up improperly
Well its definately not your water level switch, so that only leaves your water fill valve at the back of the washer, the cold valve is stuck open by debris. hope this helps
May 18, 2007 | Whirlpool LSR5132PQ Top Load Washer
Maytag Centennial MVWC700V Washer Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
