Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Side by side frigidaire
After a storm, lost power. Next day fridge is warm and freezer is luke warm. Reset the unit, power, clean coils and everything. Now the freezer is working on bottom only upper portion is warm. Same on fridge side but overall temp is not that great. any suggestions???
Thank you
  • petrk415 Jul 19, 2008
    thank you for the reply, the fan is running. How do you know if the damper is working???
    Thanks again
  • Anonymous Mar 22, 2014
    Warm water is being dispensed from the chiller water dispenser!
  • 125 Answers
Check the evaporator fan motor, behind the back wall of the freezer. If that is turning check if the damper is opening, top lt of the refrigerator compartment. I hope this helps you.
Posted on Jul 19, 2008
  • benham Jul 20, 2008
    you should be able to hear it if you turn the unit off and back on, you can also use a small mirror to see if it opens.
Why is my refrigerator not cooling properly?
Low on refrigerant gas due to a leak
Broken thermostat
Failing Compressor
Iced up evaporator
Feb 03, 2016 | Frigidaire Refrigerators
I have a side by side fridge/freezer. Occationally the freezer side warms up and the fridge side starts icing. It happens sporatically. It is a hotpoint model hsm25gftasa. Tried giving it more air
The defrost timer also turns on heater strips buried behind the metal parts that the door gaskets touch. It may be you're just witnessing the defrost cycle. If you have lost power for a time, that affects the clock time of day the defrost cycle starts. I'd look at the defrost timer and reset the time.
Oct 01, 2014 | Refrigerators
Side by side unit. no temperature control in freezer or fridge temperature of fridge is 60 degrees F on top. Freezer temp is 45 degrees. Bottom part of fridge is 28 degrees F.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 13, 2011 | Frigidaire PLHS267ZA Side by Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer and Fridge are both not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
hhsg
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Mar 30, 2008 | Frigidaire FRS26ZSG
Frigidaire FRT18HB5DW2 fridge not cooling
Sounds like an air flow problem to the lower unit. Take the sheetmetal or plastic rear cover off the freezer back wall and make sure the coils are frosted up good and even but NOT a block of ice inches thick (air needs to circulate and a blocked coil won't let air move over it efficiently). Make sure the fan is running to move the air around. In the fridge area make sure the air dampers are letting the cold air from the freezer down to the fridge compartment. Depending on what you find will determine the next steps so let us know.
Dec 27, 2006 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
190 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
