My monitor isn't receiving a picture. It reads "no input". What could be the problem?
  • 97 Answers
Well, It could be either the Computer is not putting out a picture, or the monitor is not working. It could be a video card issue. do you see anything?? like the boot process then it dies?
Posted on Jan 02, 2011
When turning on my computer I get no picture on my screen. I have checked all conections and made sure that they are all properly conected. What needs too be done?
Was your monitor previously working? Is your monitor set to receive input from the cable its connected to? There are different inputs for monitors usually. Make sure your monitor is set to receive input from the cable (vga, hdmi, DVI, ect.). If your monitor is very old, it may just be that's it's giving out. If your monitor is new, it may be that it wasn't working to begin with. If its not the connectors, then the monitor may just not be working.
Oct 18, 2012 | Star Logic 17" LCD Monitor
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
I replaced the Convergence chip on my WS55511, and now the colors align properly, so there isn't a convergence problem. But the picture still isn't right. The colors shift towards red in the...
You have your input R G B / component wires hooked up incorrectly. The tv is detecting that and letting you know. disconnect and redo observe the color matching.
Oct 06, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Hi, I have buy a Frontech External TV Tuner card. On connecting to my LCD monitor (AOC) the monitor displays "Input Not Supported", but if my computer is running fine from the card (as manual...
TV tuner cards receive an input. Your monitor should still be connected to your computer using the VGA/DVI/HDMI output. The software for the TV Tuner should take the input from the external cards input and output it to your monitor like any other desktop application.
If your Monitor is giving you input not supported from your standard video output then you may have your resolution set to high,or the monitor frequency set too high (max of 60hz typically for LCD)
Sep 06, 2011 | Computers & Internet
When turning on my monitor the Acer name appears then disappears and a box that reads "no signal" appears. Then the screen goes blank and the blue power button turns yellow.
This means that your monitor is not receiving a signal from your computer. The easiest way to fix this is to plug the monitor into the computer. I hope this helps and have a nice day!
May 03, 2011 | Acer Computers & Internet
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
The monitor reads "no signal," any ideas?
Problem in the data input board(VGA or DVI).Replace the board.
Oct 27, 2010 | Neovo F-417 17" LCD Monitor
How do I get the " OSD" to work!
Make sure that you are selecting the correct input on the TV for which input you are plugging the receiver into. Then press the OSD button on the receiver remote. If that doesn't work, try plugging the S video into a different video input, or use a different video input cable such as from the composite connection of the monitor out. Some reasons for having to do it this way is that some televisions may give priority to one input of identical type which is usually S video. For example if you are using the S video input on the front of the TV with a different device and then plug another S video cable to another input elsewhere on the TV, it may only display the picture through the S video on one input because it is using the same circuitry for both S video inputs and can't display picture from both of them simultaneously nor can you toggle between them even if the other device is not turned on. HOWEVER, there MAY be a way around this as well...try your picture-in-picture (PIP) and toggle to the PIP input that your receiver is plugged into. Still then if that doesn't provide you with the OSD of the receiver menu, then just change one of your S video inputs to a composite input.
Jan 09, 2010 | Yamaha HTR-5280 Receiver
Cant get anything when i use the two hdmi inputs in and one hdmi out to a monitor
First thing to check, If you turn your monitor on to the correct input you should be able to see an immage from your receiver. It may be a setup screen, blue screen or flash as you change inputs on the receiver. If you do not see anything from the receiver check the HDMI cable from the monitor out of the receiver to the input on your monitor. Next is the setup of the DVD player and the Yamaha receiver. Check that the receiver HDMI ports are turned on and assigned to the correct port. Check that the disc player is setup to out put HDMI and that formats like DTS are turned on if your receiver supports this. This will give you the best picture and sound out of the equipment you have. To get in to the set up of your DVD player and receiver and use the on screen display you may need to connect them to the monitor with a composite video cable first. Make sure the monitor is on the correct input. Once you have finished the setup you should be able to switch the monitor back to the HDMI input.
Aug 21, 2009 | Yamaha Audio Players & Recorders
Samsung T220HD - can't access HDMI input sources
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck.
May 09, 2009 | Samsung T220HD LCD Monitor
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
