Question about HP OfficeJet 7110 All-In-One Thermal Printer
I just replaced the printer cartridges and ran a test page print session. The printout is unreadable and looks as if either the ink is low or the printer heads are not functioning properly
    Genius:
  • 1,570 Answers
Maybe the print quality if set to text print quality, change it to photo print quality to get print quality.
Posted on Jan 02, 2011
Recently bought a kodak 3250, and had to renew the ink cartridges. i did this twice and still cannot get printer to print any documents. as far as printing pictures is concerned the printout seems to come...
itcould be the coagulation of ink in between the cartridge better dip it in mildhot water for some times and replace it wiping the water . it would do thetrick and solve your problem . it has been practically tested.
If this solution helpful/useful for you please rate my solution. THANKS FORUSING FIXYA
May 16, 2011 | Office Equipment & Supplies
I have an HP Deskjet F380 All in one Printer/Scanner/copier which is about 6months old-it has always performed perfectly but at present I`m having trouble printing photos from computer.The quality of print...
hey payne
here is a copy of your problem.
Issue The printer is working, but colors in the printed output are missing, faded, or dull in comparison to the original. Solution Step one: Check the paper Verify that the paper type is appropriate for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface. Step two: Check the print settings
  1. In the software application you are trying to print from, click File and then click Print . The Print dialog box opens.
  2. Verify that your printer is selected and then click Properties . The printer Properties dialog box opens.
  3. Click the Printing Shortcuts tab.
  4. In the What do you want to do? menu, select a task. The What do you want to do? menu lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab include:
    • Print quality: If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type: If one of the options matches your paper type exactly, choose it rather than Automatic.
    • Paper size: Make sure this matches your paper.
    Additional options: click the Basics tab, then click Advanced Features . The Advanced Features window opens.
    • Ink volume: Adjusts the amount of ink printed on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the faster the printout will dry.
    • Dry time: Provides extra drying time for slow-drying printouts. Drag the slider to the left for less drying time, or to the right for more drying time. The printer will hold onto the printout until the dry time has elapsed.
Step three: Check the ink levels NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox .
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab and then click Service this device .
  2. Click the Estimated Ink Levels tab. Figure 1: Estimated ink levels - both cartridges low
99ac57c.gif If the steps above have not resolved the issue, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
  1. Load the input tray with unused plain white paper.
  2. Press and hold the Cancel (c00636162.gif ) button and then press the Start Copy Color (c00636190.gif ) button.
  3. Release both buttons. The self-test page prints.
Step five: Note which cartridges printed which areas of the self-test page You must identify which cartridge printed which part of the self-test page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different self-test page patterns. Your self-test page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Step six: Look for defects In general, if the printer and print cartridges are working properly, the patterns (which look like grids of lines) should contain few or no missing lines. None of the colors should be missing and the colors of the blocks at the bottom of the page should match the labels below each block. Also, there should be no streaks of ink on the report. Missing lines or streaked bars If a pattern shows more than a few missing lines, or a bar is streaked, that print cartridge is not functioning properly. Figure 4: The magenta pattern shows missing lines and the bar is streaked 7e505a5.gif
Jun 12, 2008 | HP Office Equipment & Supplies
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
My ink ran low and I finally changed it (the last couple of copies were unreadable). The new cartidges are in. It goes through the printing process and the pages are blank. No warning lights or messages....
There may be settling in the nozzles of your cartridge that has prevented the ink from flowing out properly, especially if you are using a remanufactured cartridge. The first tip on this page should help:
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
I have found that using warm water gets the ink flowing better.
Jan 03, 2010 | Canon PIXMA MP470 All-in-One Printer
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Color cartridge problem
The first thing I thought of when I read your message, was whether or not your replacement cartridges were produced by HP or by another company. Also, was it a brand new cartridge or a refill? While buying ink cartridges from another vendor or "recycled" cartridges may save a buck or two, you can't always rely on the quality of the printouts they produce. If this is the case, try using an HP color ink cartridge and see if that produces better print quality.
If you are using HP ink cartridges, there might be an issue with the contact between the cartridge and carriage. It's an electrical connection and if the contacts get dirty, it can affect print quality...sometimes drastically.
Unfortunately, HP.com doesn't have a web page dedicated just to cleaning these contacts. Fortunately, they included those instructions in the following document:
Replacing the Print Cartridges
When the web page opens, scroll down to the bottom of the page and locate the task, "Fixing error messages that appear after changing a cartridge". This will contain instructions on how to clean those contacts. See if this helps.
If all else fails, try going to the following web page:
Correcting Print Quality Problems
This is sort of a "catch all" web page with a large collection of print quality diagnostic and repair techniques. If you've gotten this far wtihout a solution, perhaps something on this page will help.
Good luck.
Oct 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Won't print
Try the following steps:
Check for and remove any grayscale settings. Use the following steps to check this setting.
  1. In the program, click File and then click Print . The Print dialog box opens.
  2. Select the correct product and then click Properties . The Properties dialog box opens.
  3. Click the Color tab.
  4. Check the Print in Grayscale setting. If necessary, unselect the setting.
  5. Click OK to save the settings.
If this doesnot work:
    2. Open HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
    Now Click the Estimated Ink Levels tab. This will tell u that the cartridge might be running out of ink even if the graphic shows that there is ink remaining in the cartridge.Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • If this doesnot work:
  • If the Print in grayscale option is not the problem and the print cartridges are not low on ink, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
    2. Press and hold the Cancel button and then press the Start Copy Color button.
    This will definitely work for u.
    Thank u.
    May 27, 2008 | HP DeskJet F380 All-In-One Printer
    Low ink message
    just ignore the message and print
    if it doesn't print try to dip the lower part of cartridge in warm water, not hot, for five mins and dry it with tissue and try to print
    May 03, 2008 | HP Deskjet D1341 InkJet Printer
    Black ink print
    I think you need to perform a Head Cleaning, you should be able to do this from the HP toolbox or from The Printer maintainance wizard.
    this should resolve the problems with your printouts but may require more than one pass to restore correct printing
    Dec 29, 2007 | HP Photosmart D7145 Printer
    HP Photosmart C3100 series
    I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
    Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
    HP OfficeJet 7110 All-In-One Thermal Printer Logo
    105 people viewed this question
    Seeker5211
    Seeker5211
