Co-ax input broke off in back - Televison & Video
  • 927 Answers
Good Day, aprilpatino;
If your TV has video, components or HDMI inputs you can by pass the 'rf' connector. You must have a cable, sat box or vcr in order to do so. Hook cable output from 'box' to the TV's input. Change TV's input with remote for the proper 'hooked-up' input.
Good Luck, Big Irish.
Posted on Jul 09, 2008
I have a Seiko 50 inch flat screen tv were on the tv do I hook up a digital antenna
All terrestrial broadcast inputs go to the co ax input port, the TV will auto sort between analogue and digital inputs.
Jan 19, 2016 | Televison & Video
Will not play on my TV
Well that is not very much information to go on, but I will try to help. You need to have a video cable (either co-ax or HDMI) between the DVD player OUTPUT and an INPUT on the back of the TV. With this done, and the DVD player ON, you will need to push the INPUT button on the TV remote until you see the DVD screen. The input label will match the TV's INPUT plug name that you plugged the cable from the DVD player into.
Aug 30, 2015 | Televison & Video
Do they make a adaptor that goes from coax to hdmi or video plugs
No - co-ax is used to carry a signal at RF level while HDMI is audio/video.
A co-ax socket can be replaced by any qualified technician
May 04, 2015 | Televison & Video
Error message setup to address the power of the printer
If there is a message on LCD display to "SET THE ADDRESS" the printer will be fitted with a CO AX/Twin Ax Interface
Press CLEAR to CLEAR the error, then enter the menus on the printer and set an address for the Co-Ax/Twin Ax interface, if you are using this the address would need to match the system set up.
If you are not using Co-Ax/Twin Ax set a random address to clear the error.
Perhaps consider removing the interface if you are not using it
Feb 19, 2013 | Tally Line Matrix T6100 Printer
I have an RCA rear Projection TV model # p60812BL manufactured in 1998, no sound is coming from the tv when watching cable TV via a digital box. When the mute button is pressed and unpressed you can hear...
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
Mar 16, 2011 | RCA P52926 52" Rear Projection Television
I have a tv sky box in lounge and 2nd tv in a different room connected by a co ax cable. I need a desription or a diagram to get everything working. It worked prior to having a new carpet fitted and the...
Check first that the Co-Ax cable is firmly plugged into your SKY box in your lounge.
(I'm assuming that the carpet fitters did NOT put a nail thru your co-ax cable or pushed the cable onto any metal carpet grippers???)
If they might have done this accidentally, then, that's why it doesn't work!
Then make sure that the co-ax cable is plugged firmly into your second TV. Sometimes the central connector within the co-axial socket becomes loose and needs nipping back together with a pair of long-nosed pliers.
I'm assuming that you have plugged the Infra-red remote eye unit back into the second TV aerial socket - before you plugged the co-ax cable back in?
If you have, press the SKY remote to see if the Infra-red LED can be seen in the remote pod.
Finally, make sure that you have selected the correct channel number (or Input) on your second TV remote to select SKY.
Nov 18, 2009 | Televison & Video
DVD/CD Player with Video Cassette Recorder how do you connection to a old tv. The Old tv has no audio in or audio out for the Red, White & Yellow, audio/video cable.
The older TV's will normally only have inputs for co-ax cables labeled "antenna in" and "out to TV. In this case you will need to use those or get an audio/video converter. It has connections on it for S-video, the red white and yellow audio/video cables that you mentioned, as well as co-ax. Cost less than $20.00. That should fix your problem. Hope this helps you.
Oct 27, 2009 | Televison & Video
Is there such a thing as a co-ax cable to input converters?
Before you go that far, realize that the cable itself may be the problem. Usually poor picture quality can be traced to poor cable connections. Also, another possibility is poor connections inside the tuner of the set. I assume that you are using a cable box. Some of the newer boxes have direct video connections which will connect as you describe. Check the condition of all of the cables and connectors before yo invest in anything.
Keep us posted.
Feb 17, 2009 | HP Expresscard TV Tuner For Windows Vista...
Need some sound to my home theatre system
Just 2feb827.jpgrun red and white composite audio cables from the audio out ports above the AVin1 ports on the back of the tv to one of the audio input ports on the home theater system, remember which input port you connected it to and when you want to watch tv with the home theater sound just switch to that input on the home theater system.
Feb 04, 2009 | LG 42LG50 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
