Question about Dometic Rooftop RV Air Conditioner
Unit cools great but when extremly hot weather occurs it eventually freezes up.
Dirty filters in the indoor unit.As the ambient temperature rises the unit will work harder and longer,its fine when its just a normal day because the evaporator coil wont have time to ice up as the compressor will cycle off before the coil freezes totally,but during extreme ambient temperatures the coil will ice up as the compressor will continue running to reach set-point causing the coil to ice up
Posted on Jan 06, 2011
My kenmore 106.72102100 is not cooling or freezing properly and around the freezer door is extremely hot
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 31, 2010 | Kenmore 64802 Top Freezer Refrigerator
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Starts and runs good when cold , shut engine off after motor gets hot , will not start back. After I let the engine cool down it will start back. When weather is cooler starting back is not a problem ,...
Sounds like the coil has gone bad. This is usually the syptoms of this. When it is in the non crand status cool the coil down quickly with ice and see if it doesnt crank.
May 19, 2010 | 1994 Jeep Grand Cherokee
What engine oil do you recommend for a 2001 BMW 330i with mileage of 130,000?
synthetic 5/30 . All beamers use this.. My 2000 528i and my 2008 328i also did
The only time you night want to change is if your in freezing weather or extremely hot weather.
Feb 06, 2010 | 2001 BMW 330
Emerson quiet cool cycles every 6 mins
YOU ARE HAVEING A SHORT CLCLE PROBLEM COMPRESSOR SHOULD NOT SHUT OFF UNLESS THEMOSTAT SAY OK AT TEMP OR UNIT FREEZES UP AND FREEZE STAT SHUT COMPESSOR OFF USUALLY REALLY SHORT CYCLING LIKE YOU ARE EXPERANCING IS CAUSE BY COMPRESSOR OVERHEATING OR FAULTY THEMO SHUT OFF ON CMPRESSOR REPAIR SHOULD BE DONE BY LICENCED TECH
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
Heat gauge rises
ch thermostat sounds like it's sticking..
Jul 19, 2009 | 1996 Ford Taurus
Window AC question, normal or abnormal?
Unit low on Refrigerant. Need someone to charge system.
Jun 10, 2009 | Heating & Cooling
2000 Plymouth Voyager won't start when hot.
first MAKE SURE THE CAR IS COOL BEFORE TAKING OFF THE RADIATOR CAR!!!!!! failure to do this could result in major burns to the face!!! then check the radiator fluid make sure it is topped off also make sure that you arent just puttin water in the radiator make sure and put some actualcoolant the radiator should be filled with a 50/50 mix of water and coolant
if the problem continues you might want to take it to a shop
May 15, 2009 | 2000 Plymouth Voyager
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
M2000 heat causing trouble?
Are the fans clear from dust and debris? this is a major factor, if it keeps freezing you may have partially burnt out the processor or other component.
Mar 26, 2008 | Compaq Presario M2000 Notebook
Dometic Rooftop RV Air Conditioner Logo
183 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
