Question about Electro-Harmonix 44 Magnum 44W Guitar Power Amplifier
I have a 1995 Fender Hot Rod Deluxe, I giged out and when the amp was on for a while it would shut down i would wait and in a few min i could turn it back on. I loooked around and discovered i had the Speaker connection plugged into the EXT speaker cab with no connection to the main speaker out. could this have been causing some kind of internal shutdown of the Amp?
  • Electro-Harm... Master
  • 5,603 Answers
This PROBABLY was not the problem. When you plug into the EXT speaker jack, you connect to a 4 ohm tap on the output transformer instead of an 8 ohm out as it anticipates you have an 8 ohm plugged into the main and you are plugging in an additonal 8 ohm speaker to bing the load down to the 4 ohm tap. You will have less output plugged into the EXT jack and MAYBE you tried to get out the same volume level in which case you may have been overdriving which is very hard on the output tubes... possibly you colored the plates in them and the unit shut down for that reason.
There really isn't any thermal shutdown sensor BUT if the amp still has the problem when configured correctely, suspect the NTC (negative temp coef) device that limits the inrush current. These heat up and lower their resistance as power is turned on to reduce the surge when turning unit on. These have a habit of degrading, cracking, and failing. The device is should be near the fuse holder as it is in series with a wire from there to the power transformer. It will be about the size of a quarter and three times as thick as the same. It will have two leads coming out the edge and likely will be black in color.
Posted on Jan 04, 2011
Hot Rod Deluxe
Most likely clipping. This happens when the source DBs are too high for the amp....feeding in too hot.
Jul 17, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Crate three button foot swich how do you connect it to the amp
The Fender Hot Rod Deluxe shows a 2-button footswitch as standard but I'm confused. This link shows it as connected to the amp via a mono cable ... FENDER Hot Rod Deluxe DeVille Footswitch which is impossible using two switches. Normally it's a stereo (tip, ring, sleeve) with tip to sleeve being one connection, and ring to sleeve the other. Good luck with this one.
Apr 22, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe. Works great except when I turn the amp off it crackles pretty loud. It takes about 5-10 seconds for the crackle is heard. If I turn the standby switch first, then wait a minute or...
As voltages drop, electronics gets unstable as it goes down and becomes noisy... this may be the nature of this beast. Opening the standby might be the best way to avoid the problem.. Here is your schematic for service:
http://elektrotanya.com/fender_hot-rod-deluxe_sch.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Opening the standby switch turns off power to the main amp so noise generated in the preamp will not be amplified.
Jul 25, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My fender hot rod deluxe is distorting in clean channel when I push the volume past 2
Realize that the number on the volume control is only relative... it means nothing regarding what the amp can produce. With a high level output guitar you can easily drive the amp into distortion at very low volume control level settings... what counts is the actual output sound volume and specifically the voltage output going to the speaker. Once the amp reaches saturation, any further input just pushes it into distortion or "flat topping".
An oscilloscope on the output will quickly show when amp starts to flat top.
Jan 17, 2011 | Fender Hot Rod Deluxe Guitar Combo...
How do i connect the boss gt 10 to a fender blues deluxe amp and bypass the amps preamp
You can plug the output of the gt10 into the "power amp in" jack of the Fender. This bypasses the preamps in the Fender but uses a buffer amps in the Fender to drive the power amp. Please note that the reverb is STILL in the circuit when you do this. You can turn the reverb to zero if you wish to disable it.
Jun 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fender hot rod deluxe tube rattle.
Fender hot rod´s have an common problem on the plate resistors of the preamp and phase inverter tubes.
Check if the 100K and 82K resistors on the tube socket board are not brown. Those resistors usually need to be changed to bigger ones 1/2W.
this guy made a good document about this fix:
http://home.comcast.net/~fredholz/Justin-Holton/Fixing%20Loud%20and%20Intermittent%20Crackle%20or%20Static.pdf
Apr 01, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Jul 24, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deluxe making popping noise
Ah yes, the Fender Hot Rod Deluxe. I have seen more of these in my shop than any other amplifier!! I have even sent recomendations for design changes to Fender about this amplifier.
Sadly, your amp tech may be correct: while the amp is within working specs, you can still have an issue with a bad socket. The cheapest thing to try is to replace the preamp tube(s) you think may be causing the problem. If the problem persists, it may need to be serviced on this issue (by a different 'certified Fender tech'). In defense of the last tech you had work on this amp, these amplifiers have a brittle design and do not gig or travel well (there are a minority of these amps made that do perform). Fender tried to do too much for the price on this model: best advice is to fix it, sell it and get your tone with a more stable model made by Fender (like the new vintage re-issues). Fender, like Marshall, has for years been having problems when they get too far from thier 'working reciepe' of what made them great companies.
You likely have a socket that needs re-tensioned, or a preamp tube not behaving. If it is not these, then a tech had to dive in the house of cards that is this circuit. Sorry for the bad news on this, but it is the truth. I only take on Hot Rods that 'appear' to be fixable. I am a development engineer, build amps from scratch and fix them for the local music shops, and my success rate is a dismal 60%-ish percent on these...
Thanks,-mike
Mar 25, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Electro-Harmonix 44 Magnum 44W Guitar Power Amplifier Logo
99 people viewed this question
Top Electro-Harmonix Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Electro-Harmonix Music Expert? Answer questions, earn points and help others
