Question about Dryers
My dryer was squeaking really bad, so I sprayed WD 40 on the pulley & belt, squeaking stopped but the dryer also stopped turning. The pulley still turns but the dryer drum doesn't
  • 70 Answers
The belt is slipping now. Need to clean the WD40 off, use methylated spirits, isopropyl or rubbing alcohol on a cloth.
Posted on Jan 02, 2011
Toro zero turn wont go forward or reverse
zero turn has 2 hydrostatic transmissions. Check drive belt, pulley tensioners for clog.
Remove clog with stick instead of your fingers if in the way of mechanism, belt or pulley wheels.
Check to be sure belt is taught and pulleys move. wd-40 is ok .
Do not get wd-40 onto pulley guides, or pulleys but only to tensioner mechanism and springs.
Paper towels are good spray blockers, wrap belt in paper towels if wd-40, do not use white lithium spray but only small amounts of grease when perform full breakdown and assembly maintenance on deck and drive.
The hydrostatic pumps might be drain&fill possible if they each have a vent hole and a drain plug next to vent hole somewhere. Clean them up with carb cleaner or use starter fluid if really nasty build up. Then check for hex tool drain plug and vent hole or vent cap over hole. Do not use vent hole for topping off hydro's
Jul 11, 2014 | Garden
Dryer making squeaking noise, what causes this?
The squeaking could be coming from the idler pulley on the motor, the drum rollers or a worn drum seal. It is not a good idea to spray the rollers with WD-40. The WD-40 will attract lint that will build up and could catch on fire inside the dryer cabinet. A bad drum support roller or any other squeaking component inside a dryer cabinet will normally need to be replaced.
Aug 29, 2011 | Maytag Neptune MDE6700A Electric Dryer
Dryer squeaks
the rollers or belt idler may be corroded, use mineral oil or special bearing lubricant. DO NOT USE WD-40 OR 3 IN ONE OILS. you may find that they may need replacement.
Feb 09, 2011 | Frigidaire FEX831CS Top Load Stacked...
I have a 1998 GMC Jimmy 4x4 4 Door That has a obnoxious squeak in the front of the motor. My dad and i replaced the serpantine belt and Idoler pollies and it doesnt help. But every time you squrirt WD-40...
It is not the serpentine pulley nor idler but it need a good clean up on the pulley wheels and then spry generously the belt with belt conditioning dressings spray to minimise dry friction.
Nov 19, 2010 | 1998 GMC Jimmy
Dryer squeaks when clothes are drying
Squeaking can mean bearings going bad or the pulleys needing some oil on them. The pulleys can usually be accessed from the rear of the dryer. The bearings are a different story, you would need to remove outer casing of the dryer to remove the drum to get the bearings behind the drum. I would recommend trying to oil the motor and idler pulleys and if that doesn't fix the problem if your handy you can try to replace the bearings. Its a big job, the bearings are behind the drum and are screwed in from the inside of the drum. In order to remove the drum the casing of the dryer had to be removed, usually the front and the top (the top will sometimes tip back on hinges). After that the drum should slide out with the bearing assembly attached. Installation is the same as removal. {Note: If you find it to be too much trouble, I would just leave it squeak, other than being annoying it won't hurt anything. Also, some dryers have a compartment in the back where you can see the bearing assembly, maybe you can spray some WD-40 in there and see if it stops squeaking. The time you really need to replace the bearings is if your drum is loose, as the bearings have gone bad, not just squeaky}
May 12, 2010 | Dryers
Belt/Pulley Squeaks? (2006 Ford Taurus)
Check your belt tensioner it may have to be replaced.
Mar 01, 2010 | 2006 Ford Taurus
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
1995 Jeep Grand Cherokee squeaking and power steering
It very well could be the pawer steering pump. But to isolate the squeking sound, take that can of wd-40 and find the idler pully and tensior pully. Spray the bearing area of both pulleys. If your bearing in those pulleys are going bad then it will make that noise. If the wd-40 quits the noise at one of those tow pulleys then you know which one to replace. If its does not, then start looking to replace the powersteering pump. I take it you have checked the power steering fluid levels and they are ok?? Also, you stated that the noise started after you bought the alternator, then try a new alternator. It might of just been a faulty alternator. Happens all the time. One last inexpensive tip is replacing all belts with new. Belts get glazed over and dirty and cause noise too. One last question. Did you make sure the belts were tight enough? Just a little variance in the belt tension can make the difference.
Aug 07, 2009 | 1995 Jeep Grand Cherokee
Hot Point electric dryer squeaking when in use.
It could be one of the pulleys on the bottom of the drum. Take the top and front panels off of the dryer. Get some WD-40. Now the hard part, there is no easy way, but put your right arm in underneath the drum (the right side of the drum)and spray the pulley the best you can. This is the hardest, but the easiest way to fix this problem, without having to take the entire dryer and drum apart. I had the similar problem. I didn't completely fix the problem, but the squeak has been significantly quieted.
Feb 14, 2009 | Hotpoint NWSR483EBWW Electric Dryer
Dryers Logo
259 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
