Question about Kenmore Dishwashers
Kenmore ultrawash quiet guard standard dishwasher won't drain
  • 9 Answers
SOURCE: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Posted on Jan 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Ultrawash Quiet guard 3; can't get the
Try pressing normalwash-heatdry-normalwash-heatdry-normalwash-heatdry-normalwash-heat then all the lights come on.
Let run for a little bit. then keep pressing the start button... until the unit shuts off, then try running a cycle.
The control board has a memory in it. So if you have cold water running in it one time. It will take longer to warm up. Your memory in the control board says its taking to long to warm up. Shutting down thinking there is something wrong with your heating cycle.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Aug 01, 2009
SOURCE: Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Posted on Sep 04, 2009
SOURCE: Kenmore Ultrawash Quiet Guard 4 dishwasher - clean light blinking
I have the same problem. I called the repair guy and he told me how to do a diagnostic check on it to clear the problem out and let it run a cycle to see if it fixes itself. That cleared my problem with the light but unfortunately didn't fix my problem. Press the heated dry button, then press the normal wash button. Press the heated dry button again and press the normal wash button again. Then let it do its thing. If all the lights go out and it does not run a complete cycle, then press normal wash and start to see if it will run the cycle. To speed up the test cycle, he said you can press Start several times slowly to get it to go to the next cycle one at a time. You will see the red lights change from sensing to washing to drying and so on until it goes to clean. Then try to wash some dishes and see if it works. If that didn't solve the problem, he said it could be that there is food or other items stuck in the bottom and needs to be cleaned out. Just remove the spray arm on the back and top of the dishwasher by the 2 screws and take it out of the dishwasher. Then remove the screws at the bottom and take the screen out to get to the tray at the bottom to see if there is food stuck in there. Pay attention to how you took it apart though, so you can put it back properly. Also check the spray arm and run water through it to remove anything that might be stuck in it. If that doesn't solve it, he said it could be the heater or your motor or possibly wires burned out. I am looking at trying to remove my motor now to see if I can replace it and check that before I pay any money unnecessarily. My repair guy is so busy that he tries to help me over the phone before he comes out. Great Guy. He said that if it is the motor, the charge to replace it is not worth fixing, but if the repair is only 100 to 200, that is definitely cheaper than the cost a the same kind of dishwasher I am planning on purchasing to replace it. They say that because the do not want to work on it. A lot of times they do charge more than it's worth though, so you have to get an estimate concerning your worst possible problem before hand so you can make up your own mind. Hope this helped you. Now I will see if anyone can help me figure out how to remove the motor from my Kenmore Quietguard 4 Dishwasher. Have a great day.
Posted on Sep 28, 2009
SOURCE: model 665.13732k600 seriel FT4610713 dishes are
The film is the stuff and the old soap backing up in the dishwasher. There is no cure for this. You can have them come out and it won't get fixed because it will happen again. They did not put a large enough drain/disposal on the models. Essentially you are eating old soap - goodness only knows what is in it.
Posted on Jan 12, 2010
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
I have a Kenmore Quiet Guard and it has stopped draining. The drain line is not clogged.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 30, 2010 | Kenmore Dishwashers
My Kenmore quiet guard standard model 587-15152400 is not getting the dishes clean AT ALL. It has hot water, water is draining, have not changed soap. Don't know why?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
Model 665.13732k600 seriel FT4610713 dishes are not getting clean, they look like they have a film on them. Kenmore Ultrawash Quiet Guard Deluxe
Jan 01, 2010 | Kenmore Dishwashers
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
No power to the dishwasher
Remove the kick plate, there is a box where the power enters on right, If you have power than its most likely the control board. We have em and will assist you on the phone 704-819-6557
Mar 14, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Dishwasher 665.17979301 - Reset Sequence?
Try pushing the Sani-Rinse and Air Dry buttons back and forth a number of times.
Apr 20, 2007 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwashers Logo
256 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
