Question about NAD 2200 2Channel Amplifier
How to adjust the dc offest bios voltage on Nad 2200 not the 2200pe it hs new transistors runs for 2 hrs than pops the same 2 transistors i have the schmatics but there is no info for that??
  • 6,771 Answers
The bios adjustments are critical, especially if it is run at high volume, and the original transistors must be used. The only solution that I can think of is measure the bios voltage on the good side, you should have one or two pods right near the output transistors and see how they match up with the problem side. I find that using a sub replacement usually will get you into trouble because the bias is not a match and the hfe is to low "output" Long shot have you checked www.nad.com for customer support to see if they can offer up the procedure in a download.
Posted on Jan 02, 2011
Sherwood RVD 6095rds Hi. After a short while of about 20 minutes. My speakers cuttout like they are losing connection. Next I hear some loud pops from the speakers. And it resets itself to standby.
Sounds like DC leakage....pre-drive and/or output transistors (or IC) becoming intermittent often pass DC voltages to the speakers. The "pops" you hear are these DC pulses being passed to the speakers and the "cutout" is the protection circuitry doing its job...protecting the speakers. Speakers want AC voltages...plus voltages moving the cone in one direction, and a negative voltage moving it in the opposite direction. DC voltages push the speaker cones in a single direction and hold it there until it fails. The bad news...it's repair shop time.
Mar 29, 2015 | Sherwood Audio Players & Recorders
Hi guys. Having a problem with my NAD T163 Surround Sound Decoder. Popping in front left and right speakers when changing audio selection. Works well other than that. Please give me some suggestions w
Could be DC voltage on the speaker output line, but this will generally keep your receiver audio output turned off completely. Could be a bad muting transistor or microprocessor IC(computer within your NAD). If you are interested in having your NAD repaired, please visit my website at audioserviceclinic.com.You may contact me there. Thank you..
Jan 01, 2014 | Sony TA-E9000ES Amplifier
This is a Wagan 2003-6 400Watt with USB DC to AC Inverter. Worked great for almost a year. Recently fan was varying in speed under load. Then finally blew my vehicle cigarette lighter receptacle fuse. ...
A few thoughts on this. With the transistors, if these are a darlington style of transistor, it might show a short on a good transistor. The USB "transistor" is a voltage regulator, 12v to 5volts dc. With the inverter input, some inverters use a diode in the input to protect against connecting the inverter by reversed leads. This diode might be shorted and be causing your problem. If it comes to changing the transistors, it might be cheaper in the long run to buy a new inverter. The transistors might be problematic and might not be the only thing problematic. Experience here talking!
Feb 05, 2011 | Wagan 20036 400 Watt Power Inverter Corp
I have a nad 7600 receiver. it is cracking and popping loudly whenever you try to adjust the volume. What could be the problem
There are a couple of possibilities here. The crackling is likely to be a dirty control. Spraying it out with electronics switch cleaner that contains a lubricant should resolve that. The popping usually indicates a build up of DC current between the amp stages. This can happen because of defective coupling caps. That may take a little more detective work. Try cleaning the controls first. If that fails to reolve the entire problem, update this and we'll start looking at circuit components.
Dan
Aug 21, 2009 | NAD Audio Players & Recorders
Amp : sansui au11000 blown transistors on driver board
may i ask you did you put silicone grease in your transistor and apply a good mica insulator in all of your transistor---------look for any burnt resistor or explosive capacitor -----check for scew tie your supply voltage to earth by wrong.
Aug 03, 2008 | NAD C320 2-Channel Amplifier
NAD C350
Take a ohm meter and measure resistance from emiter to collector should have a few kilo ohm on output transistor.
If no ohm meter available , remove output transistors from circuit.
note position of transistor . you have a NPN and a PNP for each channel.
Replace fuse and power up. If fuse blows check bridge in the power supply.
80% of the time output transistor burn and blow the fuse.
before replacing output transistors check driver transistors they probably burnt also
Apr 29, 2008 | NAD C350 2-Channel Amplifier
Won't stay on even in standby
The voltages are wrong. You should see (0.0, +/-0.6, and B+/B-) on the 3 pins. The driver section has a problem. Check the driver stage for shorted transistors or open resistors.
Dan
Mar 19, 2008 | NAD C320 2-Channel Amplifier
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
NAD C740 no longer reproducing music through loudspeakers
what was your amp? ic or transistorized? the output transistor of your amp may be opened, mostly it will short but because u still hear sound, maybe open and only the driver transistor are working. replacing output transistor or IC could solve the problem.
May 14, 2007 | NAD C320 2-Channel Amplifier
My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Oct 30, 2006 | Compaq Armada M700 Notebook
NAD 2200 2Channel Amplifier Logo
156 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
