Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Wireless Networking Hey my problem is this, a laptop and a pc both using vista home premium. modem and a linksys wireless router. in getting them to share folders the laptop is able to see the pc but will not connect. while the pc doesn't see the laptop at all and both are using their own built in wireless cards I changed vista's firewall settings in administrative tools, cause i realised that even when the firewall is turned off in vista, the os still has default settings that they adhere to so you have to change them there. HELP
  • 2,427 Answers
Hey,, the reason why your pc cannot see the laptop or vice versa is cause you dont have public domain or file sharing enabled .. to to the follow these
1.) Click start then control panel
2.) Under NETWORK and INTERNET select set up file sharing
3.) On the task Bar select Set up a connection or network
follow the onscreen instruction to create a network and remember to leave it as public or allow Lan users to view your files..
Posted on Jul 09, 2008
Hi, till recently I was conneted to the internet (AOL) via cable connected to a NetgearDG834G v3 Modem router with no problems. Replaced PC with laptop (vista home premium) and connected via cable in the...
do your router modem got a wifi wire? or does it capable on wireless connection. try to use a windows xp not vista. it must be the problem. or configure it manually on your wireless connection in control panel. hope that helps!
Aug 09, 2008 | Computers & Internet
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Remote Assistance Firewall Issues
Use Crossloop. Each session is encrypted and doesn't require turning off firewalls in your routers. You will have to give it permission to run in Vista and XP, but it works and I've used it many times.
If this is what you're already using, go to their help page to resolve the problem.
Hope this helps.
Mar 24, 2009 | Linksys Wireless-G WRT54G Router
Toshiba Satellie P305D Wireless Connection Issue
If you are having an issue with your wireless at home, try changing the security settings on your router i.e changing the password, or encryption type.
Mar 16, 2009 | Computers & Internet
Wireless Networking With a Linksys Wireless-G WRT54GX Router?
You seem rather savvy so I won't bore you with frivolous explanation. Essentially ISPs detect the MAC address of whatever device is plugged into their network. In the case of your laptop connected wired to your modem, the MAC address of your wired adapter is what is tied to your ISP account. When you plugged in a router, the MAC address of that router was different than your laptop's wired network adapter and your ISP said "nope, not letting that connect". This is something most ISPs are doing now-a-days.
You can get around this by following these steps:
  1. Plug your PC back into the modem wired
  2. Ensure you have internet connection again
  3. Go to Start -> run and type "cmd" without quotes
  4. Type "ipconfig /release" without the quotes (there is a space in there that needs to be in there)
  5. Disconnect your PC from the modem and plug the router into it
  6. Plug another LAN cable into the router and your laptop
  7. In the same command prompt, type "ipconfig /renew"
If the computer pulls an IP address for the wired ethernet, you should be all set to disconnect the cable from the router and PC and try to connect to it wireless. If it doesn't pull an IP address, you'll need to contact your ISP and inform them that you're having trouble getting your new router to work with your existing network.
You might also consider depressing the reset button located on the back of your Linksys router to set the router to its default configuration. This would clear all previous settings if there were any and might clear up any configuration options you had set when previously using this router.
Mar 03, 2009 | Linksys Wireless-G WRT54GX Router...
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (,,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
I have an HP computer (Vista Home Premium Software) and Linksys wireless-G Broadband Router (WRT54G) installed and working. Problem--Trying to makea working wireless connection with a 2nd computer. An...
check that you have all updates for your linksys and cable modem and the new adapter you bought since your pc is old..
if that doesn't help then try the following:
i would shut down pc, uplug router power, turn off the cable modem and give it all at least 10-20 secs.. plug the other pc in the router then start up cable modem and router.. after that, then turn your pc on and see if it recognizes...
is the adapter for a desktop to make wireless of a laptop, just curious..
Feb 21, 2008 | Computers & Internet
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
130 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
