Question about Insignia IS-LCDTV32 32 in. Television
Insignia ns-lcd32-09 the volume control stays displayed on screen and will always run back to 0 when you push volume up you have to do it on the remote and on the tv at the same time it will go up and as soon as you let off it runs down to 0 again
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
  • 9 Answers
SOURCE: remote control code
Contact Insignia online or by phone. Someone in Tech support might be able tohelp you. A good repairman can come out and do it for you, but you'll need to pay for it as his knowledge is his livelyhood and he will tell you how he did it and what it is. Sometimes you have to pay to get things done right.
Posted on May 06, 2008
  • 11 Answers
SOURCE: insignia ns-lcd32
You can download the manuals from the Insignia website at:
http://www.insignia-products.com/c-14-lcd-televisions.aspx
Jerry
Posted on Dec 08, 2008
SOURCE: Verizon fios remote cant be programmed to control insignia tv
Orion code 0490 solved it for me!
Posted on Jan 21, 2009
  • 121 Answers
SOURCE: Insignia ns-lcd32-09 wont play VHS
Yes, that is correct you need composite (or coax) cabling to your TV. The unit cannot carry the VHS signal via component video or digital audio cabling
Posted on Feb 27, 2009
On the Insignia TV remote, how do I get back to being able to choose channels with Direct TV remote?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Nov 28, 2015 | Insignia Solutions Original INSIGNIA TV...
What causes the volume on insignia model NS LCD3209 to go out ? The volume bar stays lit up on screen but cant turn it back up, it also freezes all other functions except power on/off
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 13, 2015 | Insignia Televison & Video
Insignia NS-PDVD10 Speaker Volume Control
The volume control is on the right side of the player, closest to the front. A copy owner's manual can be downloaded here; select the Support tab. I hope this helps!
Jul 19, 2009 | Insignia PD10135 Portable DVD Player
Unlock codes Insignia NS-8PDVD
You may have missed a step in the procedure try this one. This information was found on the following website http://www.videohelp.com/dvdhacks/insignia-ns-7dpdvd/8394 It is dated as working on 01-08-08. I hope this information help you with your problem. 1.- Power on with no DVD inside the player; 2.- Press open on the DVD player; 3.- Press Menu button on DVD (or SETUP on remote control), (you see General Setup Page on the screen); 4.- Press the right key 3 times to select the Preference Page; 5.- On the remote control press 9653; 6.- Use the up and down key to select the Region, Select 0 for all regions; 7.- Press Enter. (This works with NS-7PDVD and NS-8PDVD)
Jan 16, 2009 | Insignia NS-8PDVD
Insignia NS-MVDS7/9 - unlock code
Dec 18, 2008 | Insignia NS-8PDVD
Padlock, blue screen
Somehow in handling the remote control I pushed a button or combination of buttons and now have a blue screen with a lock symbol in red in the top left hand corner. I've tried turning the tv off, and unplugging it, as well as a combination of buttons on the remote, but it still is there.
What do I need to do to remove the lock?
Aug 02, 2008 | Insignia NS- 27" TV27 TV
Insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
1) On the remote control type "SETUP" button
2) Select "PREFERENCES" in the menu with
3) Validate it with the button "OK"
4) Enter the code : "224455"
5) With the direction keys type:
a) Left key : < (Nothing happens)
b) Down key : v (a menu appears on the screen
with all region)
6) Select the Region : 0 (all) with the direction keys
7) Validate it with the button "OK"
8) Finish the process by typing the "SETUP" button.
Feb 26, 2008 | Televison & Video
Insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
with all region)
Jan 09, 2008 | Insignia NS-8PDVD
Insignia ns-pdvd8
Hey,
Try to use the same one as the newer version.
http://www.videohelp.com/dvdhacks/insignia-is-pdvd10/6028
1. Power on
2. Open disc tray
With remote control:
3. Press Setup
4. Select Preferences
5. Enter 253135
6. Press Left Arrow
7. Press Down Arrow
(you should be seeing "REGION CODE 1" now)
8. Press 10/0 to set REGION CODE to 0
9. Press Setup (and it's done!)
Sep 04, 2007 | Televison & Video
Insignia IS-LCDTV32 32 in. Television Logo
80 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
