My promblem is that I already have a wr 1500 wireless parkervision but i cant fine my power supply .so my question to you is what power supply do i use? I have the manual but it show you what adapter to use.
    Guru:
  • 1,705 Answers
You could try asking them at:- support@parkervision.com
or, look closely at the router, a label probably underneath, for the voltage the box uses.
Probably 6v,9v or 12v then buy a universal ac adaptor which gives you the required voltage and the correct DC input plug to your device.
Ebay or more or less any electrical shop, if going to a shop, take the router with you, easier to check out the DC in plug.
Posted on Jan 02, 2011
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
I cant turn on the wireless
there might be a problem with your power supply, if the power supply plug-in separately try to replace it to a new/another one.
Jan 22, 2011 | Motorola AP-7131 (AP-7131-66048-WR)...
The 32 inch TV started to have promblems turning on at first... then you had to unplug the unit to get it to turnn on, now you cant turn it on at all. Donthe 32 inch TV started to have promblems turning on...
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 03, 2010 | Akai LCT3285TA 32 in. LCD Television
LOST SOFTWARE TO PARKERVISION WR 1500 --- PLEASE HELP ! ! !
You do not need to have a disk for the router. The router has firmware built into the router. Make sure you have your lan into the 1 port and type in your browser 192.168.150.1 and it should take you to a screen to log in. The default is 1234 for the user and password.
You should be able to use the wizard inside of the router after you log in. Hope this helps!
Nov 20, 2008 | ParkerVision SIGNALMAX WR1500...
Need Vista Drivers for ParkerVision usb 1500
I have the driver for this. You can contact me at smpcorp@intergate.com and i will give you the cd in zip format via internet. No, I will not charge you for this. I went through the same problem but eventually found the missing CD.
Oct 08, 2008 | ParkerVision USB1500 802.11b (1500USB)...
My new alarm system / wireless router
What type of Alarm system? If that pakervision has network ports on the back there is no reason they couldn't run a cable to it and setup the security for you. I've never heard an alarm company tell a consumer "No you can't have wireless in your house" I'd need to know the model # of that parkervision because this doesn't make sense to me. If that parkervision doesn't have any network ports on it... yea go out and buy a wireless router that has ports on it.
May 01, 2008 | ParkerVision SIGNALMAX WR1500...
Paker vision router
did they tell you at parkervision that the IP address waws printed wrong in the installation manual/disc ?
try replacing the last set wiht 151 and see if you can see the router through the computer, then set up your router and network. Mine worked just fine after this little misprint
Mar 27, 2008 | ParkerVision Signal Max USB1500 1 Mile USB...
Parkervision wr 1500 ip address
congaman:
You have to connect that 'access point to your machine directly' check for the ip address as the default gateway, assign your machine an static IP from the same subnet, hit refresh in the IE and you should see the log on page of that 'own made access point'.
If the network connections give you sign of exclamation hit repair.
or
THe best option is to refresh to factory defaults, and then start settings as you like to in this access point. Hiding a network is no trouble at all, once you are inside the access point you can reset your security settings as well. So the best option will be to reset the access node.
Hope it helped!
Thanks
Dec 10, 2007 | ParkerVision SIGNALMAX WR1500...
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
