Question about Pentair 460736 Master Temp Pool Heater 400btu ()
Developed a leak after freezing weather. Have been running pool all winter.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
unless you plan to have 40 degree days and nights, try to find the leak, in the heater..if its to cold, and the unit cant do a full defrost, i suggest you unhook the unit, or rent a large portable heater and tent the unit. if you have a small leak and can repair it you are ok, if you have major leaks, you need to replace the heat exchanger on the unit..
if you plan to have further below freezing nite's you must work fast, to prevent pipes underground from bursting.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Testimonial: "thanks very helpful"
I have a splashing massive oil leak from the front driver side of the engine as if the oil was being pumped out as soon as the engine starts. I can't get to where I can see where the leak is coming fr
Hard to say unless you specify what vehicle this is. One way or another, you need to get to where the leak is in order to find the problem. In any case, start by checking the oil filter, and if it is not engine-mounted, check the hoses running between the filter housing and the engine.
Mar 28, 2015 | Cars & Trucks
Tip
FREEZING CONDITIONS IN ARIZONA MAY CAUSE DAMAGE TO UNSUSPECTING POOL OWNERS
<p>February 3rd, 2011 - Peoria, Arizona<br /> <p> <br /> <p>With the inevitable freezing conditions about to sweep Arizona, unaware homeowners may feel the financial impact of these colder conditions.<br /> <p> <br /> <p>"Arizona pool owners are prepared for excessive heat, heavy monsoon rains, and extreme wind with ownership of their swimming pool, but what they are not prepared for can cost them,"<span> said Brian Morris, of WeFixUglyPools.com</span> . "Taking minor precautionary steps during colder temperatures will save a lot of aggravation, and money."<br /> <p> <br /> <p>The National Weather Service has issued freeze warnings for Maricopa County that will remain in effect from 11 PM this evening until 10 AM Thursday morning. <br /> <p> <br /> <p>Potential damages to swimming pools include: underground pipe breakages, filter cracking, damage to salt systems, pool pumps, and valves, and potential flooding of backyards due to the damages. <br /> <p> <br /> <p>"I have actually witnessed running fountains freezing today, and that is something that I have never before witnessed," continues Brian. "To believe that it will be this cold is cause for concern because most people just do not know how to prepare for this kind of weather."<br /> <p> <br /> <p>"It's important that people be made aware of these hazards," Phoenix Resident Angela Clipper noted. "There could really be some serious damages."<br /> <p> <br /> <p>We Fix Ugly Pools has also been experiencing even colder weather at its locations in Dallas / Fort Worth, with more than 150 calls flooding their office between 8 - 9 AM this morning. Rolling blackouts in the DFW area has caused additional damage to pool equipment that was being operated accordingly to the weather. With the 30-45 minute blackouts, pool equipment damage became inevitable. The financial impact to homeowners there is already in the thousands of dollars and it is expected to have an even greater impact in the Phoenix and Tucson areas as most homeowners are just not aware of how to handle this kind of weather.<br /> <p> <br /> <p> <br /> <p> <br /> <p>For more information<span>, </span>contact Brian Morris at 602-253-4499. You may also receive a quick response by emailing: info<a href="mailto:brian@wefixuglypools.com">@wefixuglypools.com</a>.<br />
on Feb 03, 2011 | Pool & Spa
How do I winterize my Hayward pool heater
either blow water out with a blower then follow with a little antifreeze to make sure all water is out then remove freeze plugs on sides of heat exchange then remove pressure switch turn off gas valve and put a board or something on the top to keep out snow and weather
Sep 24, 2014 | Hayward H Series Pool & Spa Heater 400k...
How do you winterize a hot tub? QCA Jewel Model SUV M7
this is taken right from a jewel series QCA hot tub manual.....Winterizing
In very cold weather you may not want to venture outside to use your spa. In this case, you may move it to a heated area, or leave it as is until the weather warms. If you do leave the spa unused for a long period of time in severely cold weather, you should winterize the spa to avoid accidental freezing due to a power or equipment failure.. Follow these easy steps: Turn power to the spa OFF. Drain the spa. Use a wet vac to **** or blow out the air injectors, water jets and water suction fittings. Add 1-3 gallons of RV antifreeze, depending on the size of the spa, to all the air injectors, water jets, suction drains, and filter. Caution: Any lines not receiving adequate antifreeze are subject to freeze damage!
Dec 29, 2011 | Qca Spas Jewel Series Topaz Plus Hot Tub
How to winterize the h100id1 hayward pool heater
Make sure that you drain all of the water out of the pool heater to prevent damage during freezing weather. That is the most important thing you can do to winterize pool heaters. If you have a cover, you might want to use it to prevent weather related exposure, but as long as you have the water out, you will be ok.
Oct 29, 2011 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Openiong a pool toilet
Probably, all you did was to turn-off the tap inside the basement, so that no water would be inside the pipe during the winter, and so there would be chance of water freezing inside the pipes, causing expansion, and creating a leak in the pipe. Turn the water on inside the basement. The toilet-tank should start to refill, immediately. If it does not, there may be another tap right beside the toiler. Turn that tap, too.
May 29, 2010 | YouTube Videos
Leak in heater after winter freeze
Yes you can just be sure to leave enough room to plumb it back in when your ready.
May 01, 2010 | Teledyne Laars Laars Lite2 Heater 400000...
My Lars pool heater is leaking from within the casing.
Could also be a pin hole in the small copper tube that runs from the top of the heater to the thermostat. This has happened to me a few times. Small hole, but lots of water comes out. Get some 3/8" copper tubing and 2 compression fittings. It is easy to replace this tube. The only pain is that you have to take off the top of the heater to reach the end of the tube.
May 16, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
How does heater work to keep freeze off pool in winter
What state do you live in, what is the brand name and model number of the heater. If you live in a state that gets cold during the winter, call you local pool store and schedule a closing. If the pump is running and water is not circulating, most likely the pump lost prime or your filter needs to be backwashed, or there is some debris in the impeller.
Nov 25, 2008 | Hayward H Series Pool & Spa Heater 400k...
Pentair 460736 Master Temp Pool Heater 400btu () Logo
100 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
