My Reddy heater pulses when it runs - Heating & Cooling
  • 674 Answers
This probably has something to do with a dirty fuel filter or the air pressure. Check the fuel filter and clean or replace if necessary. If that doesn't help, check the air pressure. The black box on back of the blower motor has 2 ports. One screw has a hole in it and is used to adjust the air pressure. The other doesn't have a hole and is where you can install a pressure guage to check the pressure. The required pressure is listed on the label on the side of the heater. If you can't get the pressure high enough, the air filter may be dirty or there may be a problem with the compressor. Let me know if you need to know anything about the compressor.
Posted on Jan 03, 2011
Reddy heater 60 starts runs a short time and cuts off
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 26, 2011 | Reddy Heater 60,000 BTU Kerosene...
The heater runs but it pulses when it burns
The first thing I would do is to clean burner ports and make sure that outlet screen is clean and free of any carbon build up. I would also make sure that fuel is fresh and filter is clean. Hope this helps you. Thanks
Nov 29, 2010 | Reddy R155D Utility Heater
55000 reddy heater unsteady flame
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 03, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
I have an older 100,000 btu Reddy unit that was pulsing. Put new diesel in and problem went away for awhile. Now pulsing again.
might have a clogged fuel filter. try to drain and replace. run fresh fuel. the pulse also could come from too much fuel causing a burst in the main heat exchanger. if this heater is older than ten years i would trash it and buy a new one so you dont blow up
Sep 12, 2009 | Reddy Portable Forced Air Propane Heater...
Reddy heater blows cold air
heatman101
Dec 30, 2008 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
