FixYa.com
Tags:
Vacuums
Generic problem for all Electrolux Vacuums
I HAVE A ELECTROLUX VACUM
posted by wog_boy93 on Jul 09, 2008
I HAVE A ELECTROLUX VACUM CLEANER WHICH IS A 1800w BUT ITS NOT SUCKING ANYMORE?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 09, 2008
Not Rated (0)
Ajuz
Rank:Wiz Wiz
Rating: 83%, 15 votes
hello customer,
Suspect a tripped breaker, broken on/off switch, or a damaged cord if the motor won't run.
Step12Insure that you aren't running too many appliances on the circuit if the breaker continues tripping. If that's not the problem, you may have a short circuit in the power cord. Replace it immediately to avoid fire hazards. Step23Check to make sure the bag isn't full if you aren't getting much suction. Replace the bag if it's full. Step34Make sure the hose is properly connected to the machine and that there are no obstructions in the hose or fan. Step45Repair a cracked hose with duct tape. Prevent creased hoses by hanging them over two pegs on a closet wall. Step56Remove hair and strings that tend to get wrapped around the vacuum brush with a pair of small scissors. hope u find this useful.thank you.
Comment by Ajuz, posted on Jul 10, 2008
Please Rate the Solution.. Thank You..
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Electrolux Lux 7000 Bagged Canister Vacuum Electrolux EL1000A2 Pronto Bagless Stick Cyclonic Vacuum Electrolux Little Lux Bagged Handheld Vacuum Electrolux ZB271 Bagless Stick Cyclonic Vacuum Electrolux Central Vacuum Electrolux 1910 Bagless Upright Vacuum Electrolux EL6988A Bagged Canister Vacuum
Can you Help with these Vacuums problems?
Vacuums
Miele S271i
My vacuum refuses to start. Is... Answer This...
Vacuums
I have a meile S271i
I have a meile S271i vacuum... Answer This...
Vacuums
The filter isn't spinning the
The filter isn't spinning the... Answer This...
Vacuums
HOW DO i change from
how do i change from vacuum to... Answer This...
iRobot Roomba Red 4100 Bagless Robotic Vacuum
Wheel error
This Roomba worked fine, but... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
