Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Got a frigidaire fdb1050rem1 dishwasher the clean light stays on and to get the dish washer to work again half to unplug. washes fine then clean light comes back and u have to unplug to wash again
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
SOURCE: not cleaning and leaving soap residue
make sure that your unit is getting enough water. the hose may have gotten pinched some or your pump may be going bad.
Posted on Jan 23, 2009
kram26
  • 544 Answers
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Posted on Mar 18, 2009
  • 677 Answers
SOURCE: cloudy residue on dishes after washing dishwasher is only a year and a half old what can i do ?
you need to check out this new product designed especially for this problem. it is guaranteed to work! it filters the water going into your dishwasher removing the hard minerals that cause these spots. get it at www.dishwasherfilter.com
Posted on Jul 07, 2009
SOURCE: Maytag Quiet Series 100, Model # MDB5600AWS, built
We also have a Quiet series 100 and had the same problem, the dishes always came out dingy or with food all over them. My washer is about 5 years old and worked well for about 4 of them but the last year has been doing a poorer and poorer job washing the dishes. I finally broke down and removed the racks and all of the plastic parts from the inside of the washer. Doing this revealed that the groves in the under side of most of the plastic parts was clogged with food and debris. After a good scrubbing with water and a brush then reassembly it worked like a new washer again, cleaning the dishes very well and the best part is it saved us about $700.00 for another washer.
Posted on Jan 04, 2010
Frigidaire dishwasher model FDB520RHS2 will not advance pst wash- just keeps washing draining and refilling the wash. does not advance. Left it run for 3 hours, still wash only
We had a problem with our dishwasher, it just went crazy one day and lights would light up but ours did not wash or anything...anyways upon further investigation found out by taking 6 large round head screws off,, the handle and outer cover came off, then there was a cover that was covering a circuit board and this was the brains of the washing machine, ordered the part from sears 160.00 and washer is all set. good luck. oh ya, upon further exam. when I took the board off could see discoloration on part of the circuit board. this means burned out resistor or fuse.
Mar 22, 2014 | Frigidaire Dishwashers
DISH WASHER STARTED BY IT SELF
If the resetting at the household circuit breaker has not proven to be successful, then you would need to contact a professional to have the control board and panel diagnosed for repairs.
Sep 23, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    Dish washer the clean light stays on and the dish washer wont run
    Hello & Welcome to FixYa
    Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
    High temp wash-heated dry-high temp wash-heated dry
    Please get back to me if you have any other questions.
    Kevin
    Jul 15, 2011 | Whirlpool Dishwashers
    Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
    Your dishwasher has clogged water ports.
    Start the dishwasher with NO dishes in it.
    Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
    That should clear out the residue.
    Change your dishwasher soap to the FINISH brand name for happy clean dishes.
    Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
    My dish washer dose not start, it keeps yieling "
    Hi enasammar, First thing to do is to reset. Merely unplugging the power cord from the wall socket for 4 hours, then power up again.The purposed of unplugging is to dissipitate the stored current in the memory IC thats control the unit to hang up, so it will gone. Take out all inside the unit and clean,then turn on . If still not working give me the model number so i can find the schematic diagram for that unit. Hope it may helps.
    Regards: VOTIT
    Dec 03, 2010 | Frigidaire Dishwashers
    My frigidaire dishwasher model #fghd2433kf1
    It is in a delay wash mode.
    Disconnect power for 60 seconds.
    Re-connect power.
    Press the Cancel button.
    Press the regular wash cycle and start the dw.
    Jul 17, 2010 | Frigidaire Dishwashers
    Maytag Quiet Series 100, Model # MDB5600AWS, built in dishwasher. Does not get the dishes clean, dishes stay dirty after multiple cycles of washing. Please help!
    Jun 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
    Washing and Drying lights blinking.
    DEAR FRIEND,
    ngfam1 here for you!
    I am happy to be of assistance!
    Drain is clogged at the bottom or bad pump!
    I would call service and get along with my life!!
    For this problem you will need to use factory service!
    Here is the service company I refer my appliance customers too!
    A&E Factory Service
    A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
    1(800) 905-9505
    If this dryer is 10 years old or more do not spend any money on it!
    The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
    It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
    You will be fine now!
    Thank You
    Bless you,ngfam1
    PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
    Aug 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
    Dish washer frigerdaire, some dishes do not come clean
    ck water level, a few min into wash cycle open door . make sure your water level is just below heater coil
    Feb 24, 2008 | Frigidaire 24 in. PLD2850 Built-in...
    Open Questions:
    See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
    Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
    275 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
