Question about Peavey PR15 400w PA Speakers
The blue and red cable came loose on my peavey pr 15 neo 2 way speaker
  • Peavey Master
  • 5,603 Answers
Put the red on the + side and the blkue on the - side. SECURE the wires so that their weight does not pull them loose again. You can pop amps when speakers come loose...
Posted on Jan 02, 2011
Where can i find tech service manual for Peavey PR15 speaker?
The PR 15 is a two-way sound reinforcement system consisting of a heavy duty 15" woofer and a RX14™ titanium diaphragm, dynamic compression driver mounted on a 90° x 40° coverage constant-directivity horn. The lightweight-yet-rugged injection-molded plastic enclosure.
There is no need for any other service data and there is no service manual apart from user manual. It doesn't warrant one.
Apr 08, 2017 | Peavey Music
Peavey problems
I assume you mean the Pr-12RX passive? That seems wrong to me, too. Put an ohm meter across the terminals of the horn driver and the woofer seperatly to see which, if either, is blown. If they're OK, look for a bad solder joint on the crossover.
Jul 28, 2014 | Peavey PR 12 Speaker PA Passive
PROPER WIRING FOR ATTACHING CROSSOVER TO PEAVEY SP4G SPEAKERS.
In Peavey cabinets, the lower woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the middle 15" the remaining two wires would be White + and Blue -
Mar 22, 2014 | Peavey Music
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
Dec 06, 2013 | Yamaha Music
Necesito saber que amperio tiene el fusible de entrada de una peavy pr 10
YOU MUST DIVIDE I= P/E I= AMP = P= WATTS E= TENSION
AND YOU WILL GET THE AMPS.
SINCERELY. God bless you
May 08, 2012 | Peavey Pr 10 Loudspeaker Black Nib 400...
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
Peavey Pr-15 fuse blown, speaker not working. What is the fuse rating
Actually its pretty funny thing with those speakers is the "fuse" is Actually called a Lamp in this case. These are what they call a " Red Dot Fuse ". in all the years i've been doing this i've never thought to look up the value haha. Just have to know there are Red Dot lamps and Blue dots and No Dot. If you examine the LAMP you should see somewhere close to the ends ON THE GLASS a color dot of some kind. almost like someone painted it on there. Red Dot Lamp. any parts distributer for people like Harbinger, Peavey, and B52 will KNOW what your talking about
Aug 21, 2011 | Peavey PR15 400w PA Speakers
How do i change the diaphram in a peavey pr 15 speaker
Take the hf driver off, then disassemble the old diaphragm and insert the new one, check the light bulb at crossover network to avoid late issues.
Jun 21, 2011 | Peavey Amplifier GT-15-FX - Black
What was the glowing inside my peavy pr 15 pa cabinet when I turned up my treble on my pa amp by accident? There was no damage I was just curieous as to what that glowing was
There is a speaker protection circuit that uses a lamp that will light IF you are driving the spoeakler TOO HARD !!! You can search for "Peavey speaker protection" circuiot online.
Jun 13, 2011 | Peavey XR 8600 / PR 15 PA Package
Peavey PR15 400w PA Speakers Logo
216 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
