Question about Thermador SC302T Electric Double Oven
Hello: We have a Thermador SC302TS double oven. When turning on the top oven, it will preheat to about 320 degrees, and then start cooling off. There are no messages from the panel, and the bottom oven works fine. The top heating element works, but the bottom element does not. I pulled out and disconnected the bottom element to test for connectivity. The bottom element does conduct. That indicates to me (perhaps I'm wrong) that the heating element is OK, and something else is broken. Any clues on how to proceed? -Andy
  • asm5988 Jan 02, 2011
    Thanks for your answer.
    I don't think it can be a control knob (there aren't any), or a thermostat problem (it does appear to read the preheating temp, goes up, and back down, and reads high temps when on broil.
    My hope was to track down the source of the problem, rather than list the possible issues.
    Thanks Daniel. Further experimenting shows that the convection oven works perfectly (which seems to imply that the temp sensor and door switch are fine. In your opinion, that would mean that I should replace the electronic control?
  • 4,323 Answers
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...
Daniel
Posted on Jan 02, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott Jan 02, 2011
    Oven works fine but the top one wont preheat so it can be the sensor not the control, thats the reason I wanted you to check it before replacing.
  • Daniel Scott
    Daniel Scott Jan 03, 2011
    Hi
    If sensor seems to be fine then its the control board or the wiriing to the control board.I would suggest you to use multimeter and check the wiring to the control board. Also, make sure thst the relay on the control board are not burnt. Replace the control board if wirng connections looks Ok. Hope this helps... Please post back if you need more information.
    Daniel
  • Daniel Scott
    Hi
    If sensor seems to be fine then its the control board or the wiriing to the control board.I would suggest you to use multimeter and check the wiring to the control board. Also, make sure that the relay on the control board are not burnt. Replace the control board if wirng connections looks Ok. Hope this helps... Please post back if you need more information.
    Daniel
    Check the parts and exploded diagram for your oven at this link--- Thermador SC302TS Parts
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you may have a thermostat issue or control knob issue. or a defective heat coil. your connectivity test is not a valid test method.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
How do I stop my Thermador Oven SC302TS from beeping F7
Check this link for possible solution. It says that a function key may be stuck or you may have a problem with a control board.
Thermador Fault Codes AppliancePartsPros com
Feb 24, 2015 | Thermador SC302T Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
My thermador double oven does not turn off for 30 minutes.
Welcome to FixYa.
Please clarify if I`ve misunderstood what you`re asking, but with all Thermador ranges and wall ovens ( including your SC302T model, most brands in fact ) the cooling fans will remain on for quite some time after actually shutting the oven off.
This is done by design to keep the electronics cooled to a temperature usually below 200°F so they aren`t damaged.
Heat after all is the thing which damages electronics more than anything else.
I do have use and care guides available via email attachments in "pdf" if you need one.
Thank you for choosing FixYa. I hope this eases your concern. Please let me know.
Regards,
Macmarkus :)
Sep 07, 2010 | Thermador SC302T Electric Double Oven
Error F5 comes on when trying to bake
Ok, this is a control fault that may or may not be solved by initiating a hard reset. To initiate this reset, you will have to unplug the entire oven for 3 total Min's. it is vital that you allow three total Min's before you power up once more. if you cant reach the actual plug, you can shut of the appropriate circuit breaker as well for three total Min's. Once the hard reset has been initiated, power the oven up once more. If the same problem still exists, you will have to replace the Electronic Oven Control Board.
Please rate and god bless:)
Apr 03, 2009 | Thermador SC302T Electric Double Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
422 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Thermador Oven Expert? Answer questions, earn points and help others
