Question about Sharp Aquos LC-30HV4U 30 in. LCD HDTV
My sharp aquos 30 inch tv will not come on. what could be the problem
    Novelist:
  • 131 Answers
Hello; I have an similar LC30HV2U for sale in my TV repair shop for $350. This is a 2 piece unit. The AV box and the monitor. I am also a Sharp authorized servicer. In the monitor there are 2 inverter boards on the right side that have an 80 % chance of causing this problem. This set counts "lamp errors" due to one or more inverters not working on startup. Once the set accumulates 5 lamp errors, It will not allow the set to come on. The first thing Sharp tells us is to replace both inverter boards. About $90 each. If those don't fix it the cost will go much higher due to a bad power supply board or bad LCD Panel. Hope this helps, John
Posted on Jan 02, 2011
How do I download latest firmware onto my Sharp Aquos LC-52LE640U?
hi does your tv have usb port if so, go to the sharp website look enter the model number of your tv look for firmware for your tv download it, then load it on to a usb flash drive, thanks
shaun
Mar 16, 2017 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Oct 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
Jul 24, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My Sharp Aquos
Burnt out pixel line. Usually the panel needs replacing
Jul 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Volume control
I am a Sharp servicing technician and I have seen this "problem" with this particular model many times. I have tried replacing the Main Board and the Terminal Board and it does not help. The reason i put "problem" in quotes is because I came to the conclusion that this is model is just not that loud. However, a few months after the initial production run, BAM, these TV's are as loud as any other TV on the market so sharp must have caught onto this.
Dec 31, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-30HV4U 30 in. LCD HDTV Logo
235 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
